Logitech Harmony 890 LCD Remote Control Logo
Posted on Mar 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It just started not responding to commands. Only tv will come on.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
170
Points
Update the remote and receiver after powering them down and back up. Worked for me
Anonymous
Level 2:
Champion:
  • Expert 208 Answers
  • Posted on Mar 19, 2010
Anonymous
Expert
Level 2:
Champion:
Answers
208
Questions
0
Helped
61676
Points
488
You may need to select the device you wish to control first. if unsucessful, then try reloading codes into remote
The tv does not responding with the remote control
Remove the battery from the remote.Wait at least 30 minutes. ZReinstall the battery and start over. You will need to reprogram the remote.
The power indicator blinks green but why won't it start?
Hi Jean,
Green light blinks means your command is reaching the the microprocessor of your TV. Still the TV is not starting means either the micro processor is no sending 'Power On' command to the power supply section or the power supply section is not 'responding' to it. There is nothing you can do about it yourself. Please consult some local TV technician.
Good Luck.
My Samsung LA32D4O3E2 HD LCD TV is not responding to the 'source' command from both remote control and the button on the Tv itself..How can i fix it?
Check and replace the damaged component/s at its main board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
TV does not respond to remote commands,
I'm sure you've tried this, remote batteries is most common cause.
Make sure sensors on TV and remote are unobstructed(remote only works if line of sight to sensor is clear) and clean. Windex and Qtip. Damaged/dirty/defective remote, try different if possible (universal). If none of above works(99% chance), extreme longshot is TV circuitry.
Plasma tv wont respond to the buttons being pushed on the tv
ok ,try cleaning the remote, first.open it up and clean it with alcohol and soft cloth.let it dry.then,assemble it.be sure your batteries are ok.
2answers
NEC television code
These are the device codes that can be used for the NEC TV
0036, 0038, 0057, 0063, 0197, 0244, 0347, 0401
To let the remote automatically pick up the device code follow the follwing procedure
Step Procedure Result
1 Turn on the TV manually or use the original remote control. Tune in to channel 1.
2 Look up the brand of your TV in the code list One or more four-figure codes are shown for each brand. Note the first code.
3 Keep the TV key pressed for 5 seconds Indicator blinks twice and then remains lit.
4 Enter the code noted in step 2, using the digil keys. The TV key will now blink twice. If the key blinks once for an extended period, the code has not been entered properly or the wrong code has been entered. Start again from step 2.
5 Point the remote at the TV and check that it responds as it should. If the TV responds to all of the key commands, the remote is ready for use. Do not forget to note your code.
If the device does not respond at all, or not to all of the key commands, start again from step 2 and try the next code from the list.
More Info can be found at the following website http://www.urc.philips.com/
Thanks
Proton
Do rate the solution if it fixed your problem.
Top Logitech Televison & Video Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
