Vizio VW42LF 42 in. LCD HDTV Logo
Posted on Mar 19, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It says no signal... my time warner cable box works but my t.v still says no signal????!!!!
ruggeg
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 81 Answers
  • Posted on Mar 10, 2015
ruggeg
Expert
Level 2:
New Friend:
Cheetah:
Answers
81
Questions
0
Helped
20103
Points
160
Make sure you have your TV programed for the input coming from the cable box. Go into menu--input and select your input type,(rca,hdmi etc)
I cannot get a picture to show up. It will show the word VIDEO 1, 2 ... and the TV's menu's but no tv program. We have tried switching time warner cable box but that didn't work either.
The main board would be suspect since its not processing any signal input from any of the inputs. Try www.tvcircuitboards.com they should have a replacement board available.
Hi, I bought this tv at thrift shop last week. No instruction manual available. I got cable from Time Warner. Got the cable signal and got tv working. 3 days later no cable. I don't know how to...
If using a cable box then you want to set the TV to channel 3 or 4 as the cable box will output to one of those. If no cable box then its possible the TV's tuner is bad or your cable company only transmits in digital form requiring a cable box since this TV only has an analog tuner
1helpful
Olevia 242 and Motorola DVR Cable Box switching
Have you tried using component cables instead. One of my Time Warner cable boxes did the same thing using HDMI.
2answers
I was given this tv I need to connect cable
your t.v will hook up directly to cable. if you are asking how to hook to a digital box then you can hook it up the same as you had it hooked on your previous t.v. but if you want to get high def channels then you are going to have to take your digital box back to Time Warner and swap it for a high def digital box. or you can just call Time Warner and have a technician go to your house and swap/ hook things up for you. Hope this helps you.
2answers
Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
i bot a new tv i don't have the book for the time warner remote so i don't know how to program it to work the tv it only works cable box
where can i find how to program remote that comes with time warner cable
Programming remote control to Cable TV Box
What you need to do is contact the manufacturer of either your remote control otherwise the manufacturer of the Time Warner [aka: cable providers some times also have the info on file for their customers] they store the code information within their internal systems for their customers such as yourself. Otherwise there is normally a paper insert with the remote control or the Time Warner that would list the info for select manufacturers on there. Toshiba has pretty universal IR signals/codes so you should be okay when trying to program in the codes. The manufacturers can also assist you through the steps--believe me it can get frustrating some times!
Mitsubishi 52 lcd 120 hz receiveing time warner digital cable via hdmi cable has fuzzy and pixelated picture even on digital and hd channels. Time warner techs are comming out this week to check it out,...
The tv is fine.We see so many problems with cable provided signal that it isn't funny.It usually stems from bad cable boxes and low signal coming into the house.
43FDX10B working Great until Time Warner installed cable box
try connecting the box to a different input
also try connecting another device (like a VCR) in place of the box to see if the problem exists without the cable box
3answers
This TV won't support 1080!
Low or poor signal from the cable company. Try another signal source such as a DVD play.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
