OK on the touch pad to the upper right there is a lock icon one for the op and one for the oven press and hold top key pad for 5 sec it will display on /ONLOC , press the oven light button for 5 secs and it will display LOC off....Let me know what happens.....Also power off the unit first ....
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Thanks for your response!!
Is the Solution that u gave Worked or not?
Thanks!!
Glad to see that the Problem was Fixed. I would really Appreciate if you could Accept the Solution, if 100% satisfied from the response and Close the thread.
On range models without a keypad push button for Oven Control Lockout,
the feature can be turned on or off by pressing and holding the Start
keypad push button for 3 seconds.
To Turn the Control Lockout Feature On or Off:
Models affected:
RF114, RF212, WFE301, WFE361, YRF115, YWFE301, YWFE361,
TES325, TES326, IVE323, IVP338, IVE823, IVP858, TEP340, TGS325, TGS326
You can also try unplugging the oven for an hour if the above doesn't work. If this doesn't work, then you may need to replace the sensor for the door. Let me know how this works out for you.
Benjamin
What is the exact make and model of your oven? Unplug the power cord for one hour to reset the display
I need to know the exact make and model, can you provide this information?
Michael, that sounds like a great solution but I can't physically move the stove. It's a gas model, Whirlpool Gold,Model IMK 2333648. I tried turning off the range switches on the main electric panel for the condo, but that did nothing to remove the display.
The model # is IMK2333648; Serial # YGW395LEG Q3. I may have these reversed (ie serial # first). It's a 30" slide-in Gas range made by Whirlpool, installed (new) in 2001
Thanks to you, Michael, the problem is fixed!
Thanks - problem solved!
