Sorry to tell you but it has gone faulty, you need to take it in for repair. There are no serviceable parts inside.
Hello :
Make sure that the Wii Balance Board is placed properly in front of the TV: The blue power light should be facing away from the TV. If the Wii Balance Board is facing the wrong way, your movements will be reversed.
Check the battery life of the batteries in the Wii Balance Board. If the battery level is low, try a fresh set of batteries.
Check to make sure nothing is pressing against the bottom of the Wii Balance Board. If you do find anything pressing against the bottom
(such as carpet), try using the foot extensions.
If you are you using the Wii Balance Board on a plush carpet , try using the foot extensions. After you have installed the extensions, re-weigh yourself and check for proper results (within a few pounds
good luck .
rate please !
SOURCE: wii fit balance board
I had the same problem, the board is broken and you need to call Nintendo or take it back to the shop you got it from.
SOURCE: My Wii Balance Board says 'step off me and press
If you remove the steel footplates (with a star shaped screwdriver) ou will probably find dust or fluff on the sensors. Just wipe them clean and put it all back together.
SOURCE: wii fit balance board keeps saying please step off
Hi there.
You may want to reseat the sensors. I have written a great tip with video about this.
Let me know what happens.
Thank you for using Fixya!
SOURCE: what do you do when your wii balance board keeps
Hit there
Hi there.
This is a
rare problem ............ i faced similar kind of problem
i solved my problem with the help this repair
guide you can also try this out i hope this will help you a lot .......
all the best
Click Here
