I assume you're losing Time, Date and backlight settings? It's soldered to the circuit board on the x51 series, not a plug in like the x50's. In the x51's, it's not actually a battery, but a part called a supercap. That's a very big capacitor that wolds a lot of charge, technical stuff. Not for the novice solderer, the part's small and the board & other components are very heat sensitive. Check HTCGeeks or Mobilitysite for (too) many details about this repair. EASY WAY OUT: Some dude came up with an awesome little program you install to fake it out. You set it for how long it takes you to change your main battery and then run it any time you need to change it. It automatically records the start time and resets the clock to that plus x-number of minutes it takes you to swap batteries!!!! Waaay cool and a lot simpler than opening it up if that's not your bag!!! You can find it on either of the sites I mentioned above.
SOURCE: Battery ramdomly goes dead after super heating
You may want to look at updating the ROM. There may be a fix in a later version of the ROM
SOURCE: Why do I get a battery latch open warning Axim x51v
There is a sensor on the latch that detects when it has opened. Over time, the sensor wears down. You can put a dab of glue on it (so that the button presses down even further) or fold a tiny piece of paper onto it. You can find the sensor right above where the latch is, after you've opened the back cover.
SOURCE: i have a dell axim x51v stuck on dell logo
First check to see if any of the buttons are stuck. If that doesn't help, try a few simple things with the digitizer, the thing you write on. It could be stuck.If there are any gouges, dents, deep scratches or cracks, that could do it, it's toast - but self repairable if you dare. -However- 2 things to try first just for giggles though if there are no cracks: #1. Use your joystick & enter button to navigate through the Start Menu to Settings>>System>>Screen>> Align Screen and align the screen. Worth a try. #2. There might be some crud stuck between the edge of the digitizer and the edge of the case. That can give you phantom key presses. Take a piece of stiff paper or thin plastic and run it *gently* around under the edge where the case covers the screen to scoop out any stuff that may have settled there. Those blister packs that cut you up when you try to open them works well, credit card is too thick for my taste. #3. If it's been around water, there's a very slight chance that putting it on top of the clothes dryer for a few loads will dry it out.Beyond that, needs technical help.
