We have a Sundance spa that keeps shutting down. I disconnected the power to reset but when I turned back on,it was flashing OH and the temperature reading quickly rose to 108 even though the tub is still cold. Any suggestions?
You either have a bad temperature sensor (check the wires for damage) or a bad circuit board. I would recommend replacing the temp sensor first. If that doesn't work, pull the board and take it and have it tested.
Always Replace Temp Sensor and Hi Limit Sensor at the same time. Feel your heater after reset to verify that it is not actually overheating. Are you getting a flow error code at all ? Check for proper flow to and from your heater. Per Maryland Hot Tub Repair. http://www.maryland-hottub-pool-spa-repair.com/ or blog http://marylandhottubrepair.blogspot.com/ Contact:
410-304-2463
SOURCE: Reads OH but still cold
yes although you probably have this fixed by now. Sounds like your sensors are bad, your filter is dirty(so there is not enough water flow) or one or both of your gate valves might be closed. My best guess is the sensor(s) is bad.
