SOURCE: HP deskjet 6310 won't stay on.
hi dear
try this
> unplug the power chord while the printer is turned on
> press and hold the # and 3 button on the printer at the same time.
> while holding it, plug the power chord. wait for 5 seconds and release your hands.
> once the reset is finished, check whether you are having the same problem.
thanks
SOURCE: hp 845c orange light keeps flashing
When the orange light is flashing, either paper jam or ink problem is happening.Try unloaging & reloading the stack of paper in the main tray. Remove & reinsert ink cartridges in the printer. You may also clean the contacts of the cartridge and inside the product.
SOURCE: reset power on HP 6310xi...and gettings worse
#9 will actually delete the firmware on your printer from the sounds of it you unfortunately fried the hardware
try doing a #6 but never do a#9
SOURCE: My HP Officejet 6310 will no longer initialize.
this a internal sensor error, needs to be replaced. send to repair center.
SOURCE: stuck on self test message at Power Up
Step one: Perform a partial reset
Step two: Perform a semi-full reset
CAUTION:
Performing a semi-full reset deletes any saved phone numbers on the product.
