2002 Acura RSX Logo
Posted on Mar 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Do you have to pull intake manifold to replace starter on 02 acura rsx base 2.0 auto trans
Roger Foster
Level 3:
President:
  • Master 701 Answers
  • Posted on Mar 18, 2010
Roger Foster
Master
Level 3:
President:
Answers
701
Questions
Helped
437548
Points
3451
Hello integradub: My name is Roger and I will help. The answer to your question is no. You do not have to remove the intake manifold. But before you start the replacement .MAKE SURE YOU HAVE THE ANTI THEFT CODE FOR THE RADIO. You will need to remove the sub frame dampener and the intake manifold brackets that are in your way. Should you need further help please just ask. Please rate the answer you received as this way I know it was helpful. Thank You for using Fix Ya. Roger
Rsx wont start changed the starter now it revs up then shuts off
Did you pull the intake manifold to change starter?? Sounds like you have a massive intake leak
2002 acura RSX diagnosed rusted trans filter (fluid leak) should I replace filter
Why haven't you replaced that filter yet? Whoever told you that you have a rusted filter should have replaced it!!!
How to replace starter on acura rsx 2004
I HAVE AN 04 ACURA RSX 2.0LV-TECH, AND IVE REPLACED THE BATTERY BUT ITS STILL ACTING LIKE THE BATTERY IS DEAD AND ITS SLUGGISH TO TURN OVER. IM LEANING TOWARDS THE STARTER BUT WOULD LIKE A SECOND OPINION.
My '04 Acura rsx jerks when accelerating from a stop.
1ST THING YOU NEED TO DO IS CK TRANS FLUILD ON FRONT SIDE OF TRANS AND MAKE SURE IT IS NOT LOW,AND MAY ALSO START BEING SIGNS OF TRANS ISSUE,NEED TO HAVE CK BY TRANS SHOP IF FLUILD IS NOT LOW SO YOU WANT DO ANY MORE DAMAGE IF CASE OF TRANS ISSUE,HOPE I WAS A HELP
1helpful
Just replaced the starter on a 2002 Acura RSX. had to remove the intake. after the motor warms up the RPM's start to hunt. Did not replace the intake gasket. could this be the cause?
If the RPM's are going pretty low to where the car seams like its about to die, then it could be a vaccum leak. Whick could be cause by a bad gasket or something maybe didnt get sealed right when putting everything back together. If you do decide to change the gasket, i would recommend the "Hondata Intake Manifold Gasket". Its thicker and not made from metal and also keeps your intake manifold cooler.
1helpful
2answers
Check engine light on a 2002 Acura RSX
Just hit the reset button, i have a 03 Civic Si same motor as base RSX mine came on everytime when i kept disconnecting the plug, never came back on. (i have a short ram intake)
1helpful
3answers
2003 acura rsx 68 k engine light on
i got the same computer reading on my 2002 rsx-my emissions reading was just fine. i have done nothing about replacing and/or repairing the oxygen sensor for the past year and no surging or anything. i also wondered if using ethanol gas had anything to do with messing up the sensor as it was too much of a coincidence that after using two tankfuls of ethanol gas, the engine light came on
2answers
Need a code for my 02 Acura Rsx type S
I had the saem problem, you should have a code that came with the manual its on a card and it will give you the password. If you dont have one take it to a honda/acura dealership
1helpful
2003 acura rsx cough sputter
Sounds like intake air system, look for cracks in hoses (possible intake manifold gasket) all vacuum hoses and connections. Make sure TPS and all filters are clean. Sounds like a lean mixture/flooding issue. Common problems with FWD is the Air Intake Hose, lots of flexing. Cracks form on the bottom and debris comes off inside over time(thus fouling the TPS downstream). Remove inspect carefully, If it is hooped you can fab one up yourself with PVC and some clamps and Aluminium Dryer Ducting. With the proper alignment and bigger airways you will boost your performance. The TPS can be cleaned with Carb Cleaner, replace the air filter and then test with a Vacuum Pressure Gauge install in line, directly off a Intake Manifold Vacuum port.
Try that and get back to me? I'll be around...
Top Acura Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you an Acura Expert? Answer questions, earn points and help others
