Pine Technology XFX MIA78S8209 GeForce 8200 HDMI 1333Mhz FSB AMD Socket AM2+ DDR2 ATX SLI Ready Motherboard Logo
Posted on Mar 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Motherboard replacement I put together a computer awhile back, with the XFX MIA78S8209 AM2+/AM2 NVIDIA GeForce 8200 HDMI Micro ATX AMD motherboard. From what I've read, I'm going to have to replace it. Keep getting d5 message, and try all the solutions posted. I want to replace it, but I'm not sure what the best motherboard to replace it with would be. I'm quite sure it's an AMD 2+ PCU and I'm using DDR2 667. Right now it's a Micro ATX. Do I have to get another Micro ATX Motherboard? Or could I use a regular ATX. I can't be sure if the case is only set for Micro ATX and don't know how to find out. Thanks
Anonymous
Level 2:
Champion:
  • Expert 218 Answers
  • Posted on Mar 18, 2010
Anonymous
Expert
Level 2:
Champion:
Answers
218
Questions
Helped
44755
Points
430
Ok it goes with size of board and there will be screw holes under the motherboard and spacers on the holes for yours if it will only fit a micro then youll need to get a micro board if the case has room then you can get a normall size board my advice here tho is to replace the board and the cpu i would get a 775 motherboard with pci e and ddr 2 you can get one from ebay for 35 pounds new and 10 pounds used and you will get a pentum d 820 used for about 10 to 15 pounds its a cheep way to upgrade as this is in my op the best boards around and the cheepist best cpus (you can alsow get micro boards 775 socket like the bio star board ) hope this info is of some use to you
German Isales
Level 1:
Scholar:
New Friend:
  • Contributor 65 Answers
  • Posted on Jul 09, 2010
German Isales
Contributor
Level 1:
Scholar:
New Friend:
Answers
65
Questions
Helped
84515
Points
79
I have the same motherboard there is no problem with it just update the bios on the motherboard then flash them is easy go to their website and download the new bios. If you want i would like to buy the board from you name a price. my email is [email protected] thanks
Compatible Gateway Motherboard
BIOSTAR MCP6P M2+ 6.X AM3/AM2+/AM2 NVIDIA GeForce 6150 / nForce 430 Micro ATX AMD Motherboard
1helpful
What is a compatible replacement for a m2n78-la motherboard
This motherboard's full name is ASUS M2N78-LA and also used from HP/Compaq with the name: Viola-GL8E. A good replacement solution for this board is Zotac GF8200-C-E GeForce 8200-ITX WiFi AM2 DDR2-1066 (about 130$). Here are some links for this board: from Nvidia for specs and from Amazon. Take care that the original board is micro ATX factor and the suggested one is ATX factor, so you may have to check the available space in the tower.
Stelios
Display Flicking, some times it doesn't detect any hard disc,
it may be problem with motherboard drivers or else it may be virus also. Uninstall the driver and install it. if not worked pls let me know. Update the antivirus and AGP drivers
GIGABYTE GA-M61SME-S2 AM2 NVIDIA GeForce 6100 Micro ATX AMD Motherboard Will not post, tried clearing CMOS, moved memory chips around. Still does not post.
Is this a new board? Check the processor to make sure that it is seated properly. You will have to remove the fan and heatsink, but if you put the processor in yourself, it is possible that it didn't seat properly.
2answers
STOP : 0X0000007E (0XC0000005,0XF748E0BF,0XF78dDA208,0XF78P9F08) PCI.SYS-address f748e0bf base atft487000 date stamp 3b7d855c
Hi there, The error message is caused by bad memory module. replace it one by one, then test again. hope this helps, let me know your progress
2answers
Top Pine Technology Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Pine Technology Computer and Internet Expert? Answer questions, earn points and help others
