Can't find instructions on display panel? Anyone know?
This is what worked for me :
program, **, passw 1234, you change the time/date, and then to store, press Autodial or store button.
Hope this helps!
Caroll
Press Prog, **, 000, password which is 1234, set the time, press enter on the jog wheel, lift the handset and replace and you should be good to go. Worked for me.
Press the message button on the bottom near the HOLD button then press CLEAR.
"push prog then ** then 1234 for password then "000" for date and time mode." it will keep blinking on the numbers than push the "Auto dial" "Store" button pick up and hang up the handset and it will save it
Please help me.
Push prog then ** then 1234 for password then "000" for date and time mode. Good luck
I cannot change the time on my phone. (Panasonic KX-T7633)
I tried what someone else said "push prog then ** then 1234 for password then "000" for date and time mode." It worked until you need to save the new time you have put in.
Pressing enter doesn't work, and just exiting out once you have put the new time in doen't work either.
Please help me.
when i push prog, then **, the phone beeps twice and doesn't allow me to enter in a password...still need to change time on display and can't get into it...any suggestions?
