Make sure you are on Windows 8 Desktop. Try download the Buffalo WLI-UC-GNM_E-105 driver and run setup.exe with XP SP3 compatible. After the installation, your Wireless-N150 Ultra-Compact USB 2.0 Adapter will be working fine in OS Windows 8.
I can confirm that the headset works. Suggesting two steps:
1) Confirm that you are holding both the power button AND the answer button for at least 5 seconds. When you release both buttons, the light will go on steady. Does the light go on steady? (If not, you may have a headset problem.)
2) Turn on bluetooth on your phone. Then "search" for the (now with light on) headset. (If the light is off, repeat step 1). The moto should discover the headset, and connect. It may prompt you for a pin...and the default pin code is 0000.
Hello sir,
honor to make you know that GNM-OTE3 is not a valid model of jabra products.
try to identifie your product first
you can post a photo for it and I can help you in the future.
Bye
Ok i have this same problem. I tried this sloution....it didnt work for me but it worked for alot of other people. first open your phone and turn it over. First put your right hand thumb and first finger on the area between the camera lense and the volume button. This might work but if not take it to a at&t store and you can have them either transfer the documents on your phone to another or you can have the phone refurbished because the connection in your screen might be bad. Hope this works
Go to this site, and it will walk you through each step to connect your
particular Jabra headset with your cellphone. Choose the headset, and
then at the next page, choose your phone. Moving your mouse over each
step will change the picture to what you should be seeing on your phone
at each step. http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Have you already tried to put your headset in pairing mode first? Anyway, to do it, starting with it turned off, press and hold the on/off button for some 5 seconds, until the indicator light is steadily lit (it will flash as it was being turned on, but don't release the button at that phase). Then, make your phone'sbluetooth application search for new devices. After a while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros); By the way, if your headset's user guide happens to be missing, feel free to download it from this location. Hope you are able to sort your problems out.
