Question about Rotary Thumlers Tumbler Polisher +media,rocks
Rolling Stones Rock Tumbler - no rubber ''O'' ring
My Rolling Stones Rock Tumbler does not have a rubber ''O'' ring gasket. I don't know if it ever had one. Does it require that I use one inside the rim?
  • 776 Answers
Nothing high tech here. Try it without the o-ring. If the water does not start to leak out in the first 3 to 5 minutes of tumbling you will be ok. Stop it every day to check the water level.
Set the whole thing on a cookie sheet in case it does leak when you are not watching - you don't want a bunch of rock dust and polishing grit on your table or floor in the morning.
You will not damage anything by trying it without the o-ring.
Posted on Mar 18, 2010
SOURCE:
Rolling stones list of songs
The Rolling Stones have hundreds of great songs, but here's a site that has their top picks as well as a music video and a brief description of the song's history. Hope it helps!
http://www.thewildhoneypie.com/20-fave-rolling-stones-songs/
Jun 04, 2014 | Audio Players & Recorders
I need parts for a Rolling stones rock tumbler.
You can find a refill kit online. Here is one of the sites you can buy it from: http://www.amazon.com/Classic-Crafts-Rock-Tumbler-Refill/dp/B00004NKKY
Jan 08, 2012 | Cars & Trucks
I received a rock tumbler as a gift last September as a gift and I love it. I believe the model number is 84637-2009-08. The barrel has popped a hole and is no long useable. The suggested...
just bought a rock tumbler for ToysRus but the barrel does not rotate i think that the toy is defected please let me know what else i could do to make the toy work thank you
Mar 31, 2011 | California Creations Dp Rock Tumbler
The gasket on a thermostat for the 2002 explorer is a rubber ring instead of the usual gasket,is this correct?
Most newer vehicle have the rubber ring type gaskets now.I know this is not a newer vehicle but say late 90`s and up.If it came in the box with the thermostat then it is more than likely the right one.I know some people will still use a paper gasket along with the rubber ring one.But it should not leak.When you remove the thermostat you should be able to see what your vehicle comes with.Hope this helps.Good luck.
Jan 28, 2011 | 2002 Ford Explorer
We have a rock tumbler and have lost the instructions. How long are we to tumble each stage? I assume that the sand goes inside the tumbler with the rocks. We need some directions.
Fill the barrel most of the way with stones, add coarse grit, add enough water to just cover the stones and then clean where the lid seals carefully. Seal it up and run it for a week, dump everything into a colander and rinse. Don't run that mud down your drain because it will plug it mightily, run it outside.
Do the same process with the fine grit, run it for another week and rinse and admire.
lp
Jan 02, 2011 | Edu-Science Toys
Where can i find a set of instructions for our edu science rock tumbler.
I used to have exactly that same rock tumbler. I have a bunch of polished rocks out in my garden that the kids and I made with that thing.
I don't have the instructions, but there are some perfectly great generic instructions on the geology.com web site: http://geology.com/rock-tumbler/rock-tumbler-instructions.shtml
I used these directions with great success.
Dec 31, 2010 | Edu-Science Toys
We lost the creatology rock tumbler instruction manual and cant do anything with out it
Hi, We got the same tumbler this Christmas. You might be able to get an manual from service@bhsciencetech.com
To get started though, Step 1 takes 2-4 days, step 2 4-7 days, step 3 2hrs, step 4 2 hrs.
To start day 1
1) rinse stones with water and fill barrel with no more than 8 oz of stones
2) Add step 1 course Grinding Powder
3) Add enough water to cover stones
4) tighten (snugly) cap on barrel to prevent leaking
5) Be sure barrel is clean & dry. Fit barrel into tumbler (fits correctly only in 1 direction). Cover barrel with safety dome.
6) Attach DC plug to tumbler and plug in.
7) Push on/off button
8) Push # of days button timer.
Extras
They suggest using a lubricant on the inside rim of lid to help removal.
Once you start the tumbling do not turn it off and leave it off - It will harden like cement inside the barrel.
It is loud so place it on a towel to help reduce noise and put it where it won't bother anyone.
Good Luck and Have Fun
Dec 26, 2010 | Toys
I need to order a part for a Rolling Stones Rock Tumbler, and can't find out where to do so
Have you already tried Sears?
You could also try hobbypeople.net as they carry all the parts.
Oct 14, 2009 | NRS Rock Tumbler
Directions for Rock Tumbler
After many attempts to find the manual, I came across this site:
http://www.rockhounds.com/rocknet/archive/messages/1956.shtml
It seems you aren't the only one with the same problem!
I hope this is what you are looking for...
Mar 16, 2009 | NRS Rock Tumbler
Rotary Thumlers  Tumbler Polisher +media,rocks Logo
368 people viewed this question
Top Rotary Tools & Hardware - Others Experts
MikePurcell
Level 1 Expert
Marvin
Marvin
raysaw
Are you a Rotary Tool and Hardware - Other Expert? Answer questions, earn points and help others
