Invicta Diamond - DIAMOND LADY'S DOME SWISS WATCH PINK Logo
Posted on Mar 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Change date on my invicta 6676
HOW DO I CHANGE THE DATE ON MY INVICTA 6676?
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Mar 18, 2010
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1814085
Points
13579
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all INVICTA watch manuals.Rate me, please.
Invicta Pro Diver 48mm 40239 Watch.
Question edited for spelling of maker.
Question moved from Computers.
Take it to a local jeweler store. The buttons need cleaning and servicing will fix it being off centre. Have a new battery are the same time.
Invicta model 12983, how to set day on the subdial
View the instruction manuals - Invicta
invictawatch.com/service/view-the-instruction-manuals
Enter your 4 or 5 digit model number to locate your watch. RECEIVE THE NEWSLETTER SOCIAL MEDIA · Terms & Conditions Customer Service Service ...Missing: 12983 ‎subdial
Setting Time Date Invicta Watch Chronograph - SmartBargains
https://www.smartbargains.com/.../Setting-Invicta-Chronograph.html
Know how to set time, day, and date in the Invicta Watch Chronograph. ... Invicta sells several different kinds of chronograph watches, with the two main ... and the Invicta Big Date and Day chronograph - the subdials that measure seconds and ...Missing: 12983
Invicta Reserve 48mm Octane Swiss Made Quartz ...
How do I change date on my Invicta 7352 ?
Usually, after unscrewing a *****-down crown, pulling the stem out one click will allow the date to be advanced by turning the crown in one direction or the other. Depending on the movement, a clockwise turn of the crown may advance the date and the counter clockwise turn might advance the day of the week, for example.
If all else fails, pull the stem out two clicks and advance the watch hands 24 hours for each day you wish to advance the date.
8helpful
I just got a Invicta Corduba watch and I need to set the time. How do I do that? The number on the back is #6675. Thanks
this watch has a screw down crown. lift up the protector bar or start to unscrew down until it pops out, then turn slowly and pul gently all way out. set the time . tere is 2 positions there. full out time and inbetwwen them is the date and day settings.when there turn up or down until date chages, if it has day and date , up is day down is date.you have to turn few times for it to move..set the date ,set day before and go around . the 12 see number change to might date, set the correct time am or pm. push the crown in and screw in up til hand tight.
Invicta 6280 , how to set time and does the large second hand move ?
Pull crown to position 1 and change date to yesterdays date , then pull crown to position 2, wind clock untill correct time appears (observe when date switches to observe the clocks am/pm cycle, this is useful to ensure the alarm goes off at the right time of day when set)
4helpful
Hi, I just purchased an Invicta 4718 watch, and although I have the date set correctly, the DAY is wrong. Does anyone know how to change the day?
Pull crown out 1/2 way to fist click. Rotate one direction for date and the other direction for day. Should be clockwise (right) for day and counterclockwise (left) for date.
1helpful
Need a manual describing how to set the date for an Invicta Reserve Subaqua 6208
mcdevito75 here, Best Bet, online to shopnbc.com to Invicta watches, or give Invicta a call , info at the website at ShpNBC.com
Invicta model 4562 7750 valjoux automatic movement. Day and Date are difficult to set. Move crown to second (B) position, sometimes the day of the week adjusts, then the date will not adjust moving the...
Hi Friend,
Please check with the below link,which gives the detailed information about the Invicta Watches.How to set the Date and time in your watch.
http://www.invictawatch.com/support_files/instruction_manual/Manual-HiRes.pdf
If you have any Clarification please write back to us
Regards,
Aysaam
Jun 13, 2010 • Watches
2helpful
Invicta model 4127, how to set day, date on the subdials
I don't have this model, but normally, invicta dates are set by pulling the crown out half-way and turning counter-clockwise.
Top Invicta Watches Experts
Ngoro
john h
Are you an Invicta Watch Expert? Answer questions, earn points and help others
