1997 Honda Civic Logo
Posted on Mar 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need help looking for all the sensors on a d16 honda civic
Anonymous
Level 2:
Sergeant:
  • Expert 202 Answers
  • Posted on Mar 22, 2010
Anonymous
Expert
Level 2:
Sergeant:
Answers
202
Questions
Helped
137147
Points
655
What sensor are you try to look for?
here is the list of all the sensors for 97 honda civic EX
1.Countershaft Speed sensor
Driven Pulley speed sensor
Engine Coolant Temperature Sensor
Front wheel sensor
Fuel Tank Pressure Sensor
Intake Air Temperature Sensor
Knock Sensor
Mainshaft speed sensor
Manifold Absolute pressure (Map) sensor
Primary Heated Oxygen sensor
Rear Wheel sensor
Secondary Gear shaft speed sensor
Throttle Position sensor
Vehicle speed sensor.
I hope this can help you, please put something on the ratting. good luck.
2answers
Knock sensor location on a 2001 Honda Civic DX
images for Knock sensor location on a 2001 Honda ...
Honda knock sensor p0325 - YouTube
? 6:41
https://www.youtube.com/watch?v=yacSiSJ5Vc0
Feb 17, 2014 - Uploaded by Cody the Car Guy
do you know where is the knock sensor on a 2005 Honda accord coupe .... 2001-2005 Honda Civic Cam ...
Civic knock sensor - YouTube
? 1:28
https://www.youtube.com/watch?v=D1jk5OxuOB0
Jan 18, 2015 - Uploaded by chriizt1an
96-00 civic ex. ... Civic knock sensor ... 2001-2005 Honda CivicCam Position Sensor TDC Sensor & Valve ...
Honda Civic Knock Sensors - AutoZone
tip
How to install a subwoofer and amplifier
When installing any electrical components always remember to unhook the battery. First thing you want to do is run your ground cable from a volt meter to a body or frame nut or bolt near by in the trunk or hatch area a shorter thicker ground is best then connect the other end of your volt meter to your battery cable that will need to be run through the firewall and connect to the positive battery terminal. Also VERY important make sure you have installed a fuse on the wire in between the amp and the battery. after you have connected the battery cable and ground to your meter it will light up or give you the correct reading for your ground, if not run the ground somewhere else until you have found the right spot. pull out your stereo, for stereos that are made to be compatible with an amp there will be multiple rca jacks in the back of the stereo. For a sub woofer you want to hook the rca cable to the rear or sub labeled rca jacks. Then run your amplifier remote wire to the remote wire protruding from the back of your car stereo. After that you can run the ground and battery cable to the correct slots. Now connect your sub via rca and your done. making it fit correctly is up to you. If you do not have an amp with a subwoofer out then you can take the wires from your sub and bridge the connection to your amp and get enough power, take the positive wire to your sub and hook it up to the positive terminal of channel one on the amp then take the negative wire from your sub and hook it into the negative terminal on channel two and your done.
keywords: subwoofer, fuse, wiring, car audio, car , car audio install, speakers, dvd player, in dash, acura integra gsr del sol honda civic itr ls b16 hatch coupe jdmkey words: honda acura integra gsr itr jdm del sol coupe hatch ls si boosthonda, acura, civic, crx, si, hx, two door, integra, DA, EF, EG, EK, DC, DC2, DC4, hatchback, four door, GSR, LS, GS, RS, EX, DX, VX, engine, transmission, VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15,key words:VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15, integra civic, b18, turbo spoon,JDM,EK9,da6,eg,civic,HB,honda,acura,turbo, acura Honda Civic Integra EG6 EK9 EK4 DB8 DC4 ITR CTR civic honda jdm integra ls gsr b16 b18 civic si crx k20 swap hatch coupe lx eg ek ef b20 accord prelude sedan trade sir type-r lsd b18c5 b18c1 turbo supercharger b-series integra da dc eg ek ex gs rs ls gsr lsr rs si sir sirg wanted prelude accord transmission eg ef ek em ep civic integra del sol s2000 s2k rsx accord gsr type r itr ctr vtec v tec honda acura blades ls mesh rota volk 4 lug 5 lug b16 b18 h22 h23 b20 k20 d16 d15 b series h series d series turbo all motor eg ek da ef crx dc2 dc5 dc em ej ap1 f20 prelude jdm edm ukdm doch b18a b18 b18c1 b18c5 rota rsx integra DA ef eg ek hx rims si rims gsr blades ls distributer distributor rota rotor aem injen akimoto parts works obx hatchback honda acura integra ls rs gs gsr type r civic dx cx ex hx lx si crx hf del sol oem jdm da da9 da6 db dc dc2 ef ef8 ef9 eg eg6 motor integra da dc eg ission, VTEC, V-TEC, non-VTEC, B18, B18A, B18B, B18A1, B18B1, B16, B16A, B16A2, B18C, B18C1, B18C5, D16, D15, suspension, break, brake, greddy, tanabe, cusco, zex, nos, turbo, drag, hks, aem,subwoofer powered subwoofer subwoofers svs subwoofer
home subwoofer car subwoofers best subwoofer subwoofer cable
subwoofer reviews car subwoofer klipsch subwoofer subwoofer wiring
home theater subwoofer yamaha subwoofer subwoofer amplifier
jbl subwoofer subwoofers for sale jackhammer subwoofer subwoofer boxes
hsu subwoofer sunfire subwoofer kicker subwoofers pioneer subwoofers
subwoofer car audio car audio subwoofers powered subwoofers
cheap subwoofers home subwoofers 15 subwoofer
subwoofer placement computer subwoofer active subwoofer
velodyne subwoofer mtx subwoofer kicker subwoofer subwoofer box
infinity subwoofer home audio subwoofers
car speakers and subwoofers
cheap subwoofer
home theater subwoofers
rel subwoofer
wireless subwoofer
jbl subwoofers
10 subwoofer
subwoofer speakers
8 subwoofer
bazooka subwoofer
subwoofer enclosures
custom subwoofer boxes
1helpful
2answers
Where is the speed sensor on a 2007 civic hybrid
Are you looking for the wheel speed sensor or the vehicle speed sensor?
The wheel speed sensor is located on the steering knuckles just behind the rotors.
The vehicle speed sensor is located on top of the transmission housing under the air filter bock housing.
If you need any more info or details on these sensors, let me know.
Hope this helps you.
3answers
Location of knock sensor for honda civic
Mrs PETERSON the knock sensor located on the side of the engine block to the inner side under the inlet manifold and close to the oil filter and oil switch.
3helpful
2answers
Location of knock sensor on a 98 honda civic v -tech 4 cylinder
It is on the lower left side of the engine (side towards firewall - see picture).
Knock sensor failures are pretty rare, why are you looking for it?
WHAT SIZE MOTOR IS A 1998 HONDA CIVIC EX
i believe ex model comes with a sohc 1.6l engine (d16).
My 1999 honda civic has no spark
Each plug has its own coil right? Spark is initiated by computer looking at crankshaft sensor. Some cars also have camshaft sensors. If you want to fix yourself, get a repair manual at parts store. Very helpful, good luck!
1helpful
Is it possible to make a d15b carburator engine to a vtec
In my opinion it is not worth it. In order to make your d15 a vtec engine, you will have to put a d16 head on it. That will require drilling new oil ports, converting the engine to fuel injection, changing out the computer, and a whole lot more things. You would wind up spending more money doing that than just doing a d16 complete swap. plus the d16 will have more power over all anyway compared to the d15 vtec. d15 is a 1.5L the d16 is 1.6L reguardless your gonna have more power with a d16. Just a suggestion.
2helpful
2answers
What should i do? B16 or piston rings?
well its about what you want the single cams can rev high...the 2nd fastest world record is in a turbod d16 ...202mph for a single cam civic..the b16 has more dynamics in the high end of boosting... the b16 aftermarket is stronger but they **** on the low end of the rpm gauge..
the best motor is the b20 crv block its 500 bucks you can vtec it with a b16 head and run big loads of turbo and get to the 10 sec class of things...if you go to b series you will need to change the ecu to hondata and you should look for ls integra trannys...next the axles ...I reccomend B20 its a harder build but its worth it and youll spend 1000 less than an gsr or prelude motor...google the b20 dart motor with ITBS you will see!!!!!!!!
Top Honda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Honda Expert? Answer questions, earn points and help others
