I just ran the "clean" mode on our Jenn air range/oven. It ended over 2 hours ago and the oven is cool but the door did not unlock and the oven light is on. Is there a way to manually unlock the door?
There is no model number on the unit. All I know is that the house was built in 1999 and it was new then. It is a gas stove with electric oven
SOURCE: Jenn Air Range SCE30600
i would pull unit out adn look for a bad thermostat on back wall wired inline from bake and broil elemnts, probably tripped during a clean cycle or something got to hot, common for oven to shut down because of bad safety thermo, yet stovetop function without interuption
SOURCE: jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
SOURCE: Jenn Air oven door won't open after clean cycle
You need the repair man; not a diy project. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
SOURCE: How can a Jenn-Air down draft stove be vented out the roof ?
Yes , its much more labor intense but it can be done by venting it up through the wall then through the attic over to the side vents. Make sure to get flexable duct to pull up through the wall.
Phil
Had this EXACT same problem the day before a party where I needed the oven for lots of baking.... Tried all sorts of things, was about to call a repair man- I FINALLY got it to open by following the first two directions for putting it into self clean mode (turned both knobs to CLEAN), then when it said to lock door I tried to move the lock lever and bam it worked! Give it a shot! Good luck! (:
