There is a protection switch on the inside where the replacement bulb slides out, check to see if it is either tripped or not making connection, If that doesn't fix your problem, check and make sure that there is absolutely nothing on the bulb and/or the glass shield, also visually inspect the bulb for bulges or defects, if found replace the lamp or entire color engine.
IF this is a projection tv of tube nature, you need the projection tubes degaussed. IF it is solid state, you have circuit board problems and that can get expensive...if not impossible when compared to the price of a new TV. BE very carefull of speaker placement near these tube if it is a projection tube type...get the speakers away from the sides of the tv, Turn it on and off several times. (it degausses itself everytime it is turned on)..and see if you see a lessening of the effect...if you do, then with time, this will go away.
the projection tube needs to be adjust for color alignment, each tube (red, green, blue) must be aligned so you there would be no color smear appear on screen. if it is aligned try to set up the color balance, hue etc.
You probably need to change out the semiconductors. The parts are STK392-110. There are two of them, one for horizontal and one for vertical. Search it online more.
