SOURCE: bosch tassimo
Solution: Just refill the water tank with water (no descaling solution) all the way to the "Max Line". Then run the full descaling program again --takes approx. 20 minutes. After the program runs completely you will get the yellow "standby" light on and the red "descaling" light will be off.
Next time you descale, be sure and fill your water tank to the "Max Line" before running the descaling program.
Hint: An incomplete cycle (not full tank) is what makes the red light stay on. In other words, it's staying red to tell you to run a full cycle (beginning with the water tank filled to the "Max Line"). Hope this tip is helpful!
SOURCE: Braun Tassimo 3107 or 3701
Yessir, you need a t-disc to use it, because the machine reads the bar code that is imprinted on the aluminum lid of the t-disc to get instructions of how hot the water should be, and how much water should be used for the beverage you're qnting to prepare. no t-disc, no drink, no working machine. it's that simple.
SOURCE: Braun Tassimo Coffee
It's most probably from the overflow which is situated behind the splashback. When the machine leaks from there it generally means that it needs to be descaled. You can use a general descaling agent powder. dissolve it into the water container filled to max, with the cleaning disc run a few cycles with 15 minute gaps between each cycle. after it should be fine.
SOURCE: descaling your tassimo machine
My Bosch manual is very specific: DO NOT USE VINEGAR! They recommend you use any commercial coffee machine descaler.
CLR recommends itself for the job and the Jellmar website has instructions.
