Casio G-SHOCK 200M DW5600E1V Wrist Watch Logo
Posted on Mar 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to set the time to eastern standard time - Casio G-SHOCK 200M DW5600E1V Wrist Watch
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Mar 18, 2010
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1813011
Points
13579
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals.Rate me, please.
tip
How to reset alarm with Emerson smart set alarm?
First, make sure the time is set correctly – Eastern Standard Time (EST) is the defaultPress the Alarm Mode button – it has options for Weekend, meaning Sat and Sun only; Weekdays (Mon-Fri), and Everyday
While holding either the ALM 1 or ALM 2 button, press up or down to set the correct wake-up time
Release ALM 1 (or 2) when you are finished.
This will help.Good luck.
on Mar 08, 2010 • Watches
2helpful
Silicon scientific atomic watch
Should be 4 buttons, 2 on left and 2 on right. Press bottom left 3 times and hour offset digit will be displayed. Press and hold top left until hour offset digit starts to flash. Press either top or bottom right to adjust offset hour to correspond with your time zone. Eastern -5, central -6, mountain -7, pacific -8. These are negative numbers, not positive. Then press top left button once, then press bottom left button to return to time display.
1helpful
The invicta 4048 is an atomic watch with 4 buttons only. I need to know how to set this watch. Previous experts have refered me to the standard Invicta instructions PDF. The atomic watch is not covered...
The Invicta Atomic 4048 is "discontinued", and Invicta is not very helpful. They do NOT offer an instruction manual for the 4048, because it's discontinued. You can call Invicta at 800-327-7682 then you have to ask for "Melvin" who only works until 1PM eastern time. OR you can do the following:
Hold down the 8 0'clock button until it flashes, select 12hour or 24hour preference, use the button at 4 o'clock to select your time zone (GMT) The watch should reset itself to your GMT time.
Where do I purchase extra links for my kirium band?
Contact Tag Heur Customer Service at 866-260-0460. They are open 9 AM - 6 PM Eastern Standard Time Monday to Friday
How to set analog time on Citizen JN0040-58L watch?
while crown is all the way down in the normal position , turn the crown till the mode face (the bottom circle ) goes to TME.
press the A or B button (top button A , bottom B ) to select what city where your time zone is to change . Example you are in eastern standard then you would select NYC.
Now pull crown out to second click. with normal crown position is 0 this position would be 2 .
Use the A button to find proper city again to adjust time with . the city name should start flashing .
Now just use turn the crown to change digital time. When you change the digital time the analog time is also corrected.
Push crown back to 0 position .
and you are all set
How to set tje analog time in Citizen JN0040-58L watch?
and you are all set
How do I reset the time when I move into a different time zone
mcdevito75 here, You re-set the time in a different time zone the same way as you do for the time zone your in now. The different time zones in the USA ru from 1 to 3 hours before the time in the Eastern part of the USA, example, Eastern time 3 PM, then going West, you have Central time 1 hour before, then Mountain time, 2 hours before , then Pacific time 3 hours before eastern time.
I live in Eastern Time Zone. My atomic clock shows map of USA in top right hand corner and it is set in Western Time Zone. How do I reset to Eastern Time Zone? I have had atomic clock for several years. I...
The "mode" button is there to change the function of the + & - buttons.
If you press the mode button several times you will cycle through the various setting features of the clock.
Look for the one that sets the time zone and use the + or - buttons to select your zone.
Some experimentation may be required!
67helpful
3answers
Eddie Bauer wireless thermo clock - Time zone problem
TIME ZONE SETTING
The cefault time zone is PACIFIC. lf your location is not in the Pacific zone, set the
time zone as follows:
1. In normal time mode, press the "[,4ODE" key to enter the alarm time mode. 2. ln aiarm time mode, press and hold the ADJ . 'Cl"F" key for 2 seconds to enter
the time zone setting mode.
3. Press ihe "ADJ "C/'F" key to select the proper time zone: P=Pacific
M=Mountain C=Central E=Eastern 4. Press the f,'lODE key to save and exit the time zone setting mode, or let it exit
automaiically 30 seconds later without pressing any key.
Mar 08, 2009 • Watches
Top Casio Watches Experts
k24674
Robert
ZJ Limited
ZJ Limited
Are you a Casio Watch Expert? Answer questions, earn points and help others
