GE WPGT9360E Profile Harmony 4.0 cu. ft. Washer with Stainless Steel Basket Logo
Posted on Mar 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a GE Harmony top loader washer all digital. My washer will not drain throught the drain hose. I have to lower the hose to the floor for the water to come out any ideas
Dan Webster
Level 3:
  • GE Master 8,221 Answers
  • Posted on Mar 17, 2010
Dan Webster
GE Master
Level 3:
Answers
8221
Questions
5
Helped
2380973
Points
25840
Your pump might have something in it. I got a shoestring out of one the other day. Remove the front panel and inspect the pump.I have a GE Harmony top loader washer all digital. - c8963d3.jpgbottom right of the photo is that clogged pump, The top does not pop up. The front panel comes off.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
We bought a front end loader 06-20-2008, It will run through a wash but want drain the water out, it just hums
take off front cover (2) screws at bottom. drain pump is on lower right corner remove hoses (expect water - I use shop vac) take (2) screws holding pump to washer bottom then take pump apart and remove whatever is stuck in impeller. Check hose for blockage before reinstall.( easy job except you are sitting on floor to do it !)
How do I drain the barrel
If this is a top loading washer, an easy method of draining the wash tub is to pull the drain hose from the standpipe at the wall and lower it into a bucket. Gravity will allow the water to drain. If the washer is in a laundry room or utility room with a drain in the floor, you can simply lay the drain hose on the floor and allow it to run into the drain.
A less messy method is to use a wet/dry shop vac and pull a vacuum on the drain line to pull the water from the wash tub. Most of the these top loaders have a capacity of about 30 gallons, so you will need to empty the shop vac a few times to empty the tub. Make sure you place the drain hose back into the standpipe when you need to empty the vacuum or gravity will force the water on to your floor.
If you have any questions, please let me know. I hope you find this information helpful.
Where?s the filter on my GE WSXH208A Front Loader? Thank you beltronic205 (GE WSXH208A Front Loader won?t drain). I drained the tub by lowering the drain hose as suggested. But where is the filter, what...
There is no acutal filter on this unit...You cab remove the back panel to access the drain pump ...Or tilt the washer back and access it from the bottom...Remove the drain hose from tub to drain pump...(careful of flow of water from tub)...Check the hose for any blockage...If no blockage then your pump is bad..
1helpful
2answers
Washer will not drain GE washer
If you have a top loader, try this.
If it agitates but doesn't spin or pump, it could be that your pump is seized or something is stuck in it. The agitator is operated by a different motor. Turn OFF the power. and remove the front vertical panel by inserting a drywall knife in a the top right about 4" in from edge at the joint 1" down from the top, push the clip back to release that corner, get another knife and do the same to the left top corner, the pull the top of the front panel and swing towards you, then lift off and remove. Discount the two hoses to the pump, one from the drum the other that goes to the back. Be ready for a considerable amount of water to come gushing out, use a hose to direct to a floor drain. Check to see if something is stuck in the pump or the hoses, remove it. Check to be sure the impeller spins. If you found something restricting the flow or pump, remove it and re assemble. If the impeller won't spin easily, then you need a new pump.
Remove blockage in the pump. Re-assemble and test.
2answers
Best way to drain washer to check pump or hoses
broken lid switch usely the call what kind top loader is it
Samsung
hey this soundslike your washer might be syp[hening out your water which means that the drain hose is lower than the washer.another soluthion might be leakage,how high ias the hose or is there any water on the floor? good luck
1helpful
HELP, GE profile harmony washer wont drain properly
If you remove the tub to pump hose from the pump and try to turn the pump impeller by hand, it should turn freely. If it does not turn freely, then the motor could be seized and you will need to replace the pump.
Drain hose not working
You simply have to check your drain hose and exit filter; the problem is there. When yr machine does not drain it is surely the exit filter. Refer to your user manual.
1helpful
2answers
Ge Profile Harmony Washer doesn't drain properly.
It sound like you have a blocked pump. Remove the pump from the machine and check where do you have this clogged, inside the pump or in one of the pipes connected to it. Good luck!
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
