Microsoft Office Professional 2007 Full Version for PC Logo
Posted on Mar 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't number the pages to my book properly. The program consistently starts with the number 1 on the title page. Then, I cannot get rid of the numbers without exiting the document and choosing "don't save." [email protected]
Anonymous
Level 3:
  • Master 1,049 Answers
  • Posted on Mar 17, 2010
Anonymous
Master
Level 3:
Answers
1049
Questions
Helped
286598
Points
2705
Turn off page numbers. Go to the top of the 2nd page and make a page break, choose type continuous. then setup page breaks like normal. Now 1 will be on the second page.
  • Anonymous Mar 18, 2010
    Did this fix your issue?
How to obtain Telephone book, Brisbane
https://www.brisbanepropertyvaluations.com.au/
Google chrome uninstall
1. Open Google Chrome. Navigate to the webpage that you want to be your home page. Make sure that no other tabs are open.
2. Now, go to Settings. (Click on the icon at the top right of the Chrome screen that looks like three horizontal bars. This will open a menu. Select Settings from this list.)
3. So to the section of the Settings page titled "On Startup". Click on Set Pages.
4. Click on the "Use current pages" button.
If the start page was changed without your input, it is likely that you have malware or adware on your computer. Run full scans with your antivirus software and also with Malwarebytes to try to get rid of them. Also, manually go through your programs and uninstall any malware that you find (Start > Control Panel > Programs and Features).
MY printer stopped working from on day to the next...the problem is when I print out a photo from IPhoto or Preview on my IMac OSX10.4.11 it starts with a large margin which doesn't allow for the complete...
Hello
Large photos are printed differently than regular photos.
Photos that have large resolutions or are best when printed in larger sizes are sometimes printed on multiple pages. Printing the photo on two or more pages requires setting up the printing options so that the printer recognizes how the photo should print and which areas to stop printing on each page.
Open the photo in iphoto
Select "File" and scroll down the list until reaching "Print". Click on "Print" and wait for the printing set up options. Some programs require selecting "Set up" or "Print set up" instead of "Print." Make sure the set up options are brought up according to the program.
Select "Time Imageable Table" or similar options in the program. If there is not an option with a similar title, look over the various titles and any pictures that come with the titles and see if the pictures show multiple pages or only a single page. Click on the options that allow printing one photo on multiple pages.
Select overlap options, which give margins so that connecting the pages forms the picture. Overlap around 1/2 inch or so.
Print the photo. The number of pages should match the set up options selected under the imageable table.
1helpful
How do I change Microsoft Reader as default?
http://www.microsoft.com/reader/info/tips/nolonger.aspx
Here's how to fix the problem:
  1. Shut down Microsoft Reader:
    a. From the Start Menu, tap "Settings"
    b. Select the System tab.
    c. Select the Memory icon.
    d. Tap the Running Program tab.
    e. Highlight Microsoft Reader on the Running Program list.
    f. Tap the Stop button.
  2. Tap OK.
  3. Start File Explorer
  4. Navigate to My Documents/Annotations
  5. Select and delete the .EBO file for the problem title. The correct .EBO file is the file that begins with the eBook title. If more than one .EBO file exists for the problem title, select and delete each one.
  6. Start Microsoft Reader again.
  7. Open the eBook. Let the device remain turned on, allowing Microsoft Reader to repaginate until it completes. This process should not take more than a few minutes. Microsoft Reader needs to perform this operation just once for each eBook.
How do I know if Reader is still handling background pagination on the title?
  1. Open the eBook in question.
  2. Begin reading the content.
  3. On the bottom of the Reader page, tap and hold the page number for a couple of seconds — then release it. The Riffle Control should be displayed: its appearance may take a second or two.
  4. The Riffle Control shows you where you are in the eBook. The leftmost number is the first page of the eBook; the rightmost number is the last page of the eBook. If the rightmost number is displayed in red, Microsoft Reader is not done with background pagination. If the rightmost number is displayed in black, Reader has completed pagination.
How to create book type header in docx file means double header, one for tile which must be apply for whole doc. while other tiltle may change after few nuber of pages
this will set the head on every page till you remove it.
On the View menu, click Header and Footer to open the header or footer (header and footer: A header, which can consist of text or graphics, appears at the top of every page in a section. A footer appears at the bottom of every page. Headers and footers often contain page numbers, chapter titles, dates, and author names.) area on a page.
  1. To create a header, enter text or graphics in the header area.
  2. To create a footer, click Switch Between Header and Footer on the Header and Footer toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, press ALT and then SHIFT+F10.) to move to the footer area, and then enter text or graphics.
  3. If necessary, format text by using buttons on the Formatting toolbar.
  4. When you finish, click Close on the Header and Footer toolbar.
I have been trying to get Microshaft word 2008 for Mac to start page numbers only on page 3. I have a title page, a table of contents, and then the body of my document. I have created a section at the...
1. Place cursor in each section in which you want hide the page number on the first page.
2. On the Insert menu, click Page Numbers.
3. Clear the "Show number on first page" check box.
You may have to create a separate section for your Table of Contents to suppress the page number on it.
2helpful
Designing a document in book form and printing in Word 2007
When you select Book fold for your page setup, Microsoft Word prints two pages on one side of the paper. When you fold the paper, it opens like a book. This option is intended for documents that have more than two pages.
1. Set up your document as a booklet.
When you create a booklet, it's best to start with a new, blank document so that you have better control over the placement of text, graphics, and other elements. You can add a book fold to an existing document, but you may have to reposition some elements once the book fold is in place.
A. Start a new, blank document.
B. On the File menu, click Page Setup, and then click the Margins tab.
C. In the Multiple pages list, select Book fold.
If your document is not set to landscape orientation, Microsoft Word sets it to landscape.
D. In the Inside and Outside boxes, type or select the amount of space you want for the inside and outside margins (margin: The blank space outside the printing area on a page.).
If you need even more space along the fold to accommodate binding, type or select the amount of space you want in the Gutter box.
E. In the Sheets per booklet list, select the number of pages you want to include in a single booklet.
If the number of pages in the document exceeds the number of pages you select for a booklet, Word prints the document as multiple booklets.
F. Select any other options you want in the Page Setup dialog box.
G. Add text, graphics, headers or footers (header and footer: A header, which can consist of text or graphics, appears at the top of every page in a section. A footer appears at the bottom of every page. Headers and footers often contain page numbers, chapter titles, dates, and author names.), and other elements to your document as usual.
2. On the File menu, click Print.
3. Set options for printing on both sides of the paper.
If you're using a duplex printer (one that automatically prints on both sides of the paper)
Click Properties, and then set the options you want. If you have a choice of setting the page orientation and duplex options, select landscape orientation, and flip the document on the short edge or short side.
If you aren't using a duplex printer
In the Print dialog box, select the Manual duplex check box. Word will print all of the pages that appear on one side of the paper, and then prompt you to turn the stack over and feed the pages again.
4. Select the page range you want to print.
If you click Current page or Pages, Word prints the page you indicate, plus the three other pages that belong on the same sheet of paper.
If you click Selection, Word prints your selection using the default page layout instead of booklet layout.
Sans Clip 1 Meg Player
I would try seeing if you can update the firmware, you can find Sandisk's Sansa Clip Firmware updater off to the right on this web page:
http://www.sansa.com/support/sansa_clip/faqs
Let me know how that works for ya.
2helpful
Extention Display Name
This detailed instruction is not in the small book that came with the phone. It will be found in the binder or full sized publication titled “User Manuel’ for the models KX-TD816 and KX-TD1232 that came with the phone system.
You will want to use the overlay that DID come in the smaller book. You will place it on top of the buttons and it will provide programming commands listed in the instructions.
Page 71 has the “Getting into programming” details.
[Program], **, 1234
Now you are in user programming mode.
Page 87 will instruct you how to program names.
Press 004, [Next], [jack number] (ext 101 = jack #01-1, ext 102 = jack #02-1 ect…)
Once the jack and the old name are displayed, press [Clear] and then start pressing the letters according to the “Overlay”. (3 = 3 D E F) press the S-button that displays the correct character. S-buttons are the 3 buttons directly below the display. When you are done press [Store] and you can press [Next] to se more jacks or just exit by pressing [Program].
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
