Samsung HLP4663W 46" Rear Projection HDTV Logo
Posted on Mar 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Loud rumbling/buzzing for 10-15 seconds and then power goes off
There is a loud rumbling/buzzing noise that goes up and down in intensity and volume for about 10-15 seconds when I turn the tv on. During this, the sound comes on but no picture and after that tv goes off with the lamp and timer lights left flashing. Model no. is HLP4663WX/XAA
Anonymous
Level 3:
  • Samsung Master 5,138 Answers
  • Posted on Mar 17, 2010
Anonymous
Samsung Master
Level 3:
Answers
5138
Questions
5
Helped
1004506
Points
13534
Your Color Wheel needs to be replaced!
Call Mats Electronics for Parts and supplies
1-800-628-1118
How do I tell how old my kenmore dryer is?
What exactly is this 'loud noise'? Is it a constant grinding or rumble sound that changes with drum speed or is is an occasional thumping, banging noise as the drum speeds up or slows down? A grinding or rumble is often a drum bearing and Thumping is commonly the 'suspension' the drum rides in to stop it 'walking across the room or shaking itself to pieces as it goes into high spin speeds. Your machine's age will only affect you if it is a very old machine and parts are difficult to find.
Hello! I've bought a Fender Rumble 75 about 3 months ago and it sounded great really but after some loud playing (About 75% of max volume) it started to buzz at midrange notes, and its gets worse as time...
Try plugging another sound source into the unit. The buzz MAY be pickup of magnetic fields in your guitar pickup that clobber your notes from the strings. Bad guitar cables are another possibility. By putting clean music from say a CD player into the unit you can find where the source is. If the CD player generates the same noises, then likely you have a failure of filter caps in the amp or other component failures. Also make sure your guitar can't "hear" the amp as feedback can do strange things.
1998 Lexus gs300 at idle Very loud buzzing type noise from engine
check brake fluid level.
master cylinder might be of interest, but i would check the fluid level first
2answers
Loud buzzing noise on vizio tv
It sound like you may have sound processor problem which is part of the main board, I would also look at the 12vdc from power supply to make sure it is clean DC.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=l37hdtv10a
http://en.wikipedia.org/wiki/Capacitor_plague
Buzzing sound on TV, Bad Picture...
You have a Genesis 1. Make sure that you are using the correct power supply; the first models use a different voltage than the second or third models.
Loewe Articos 55 HDTV loud buzzing noise
sorry cant solve it ,i called all the loewe service agents and they all said the same thing, put up with it. a new engine/colour wheel cost around $2500,
1helpful
2answers
Loud Buzzing noise
Sounds like the fan is hitting some ice build-up. If you can access the area of the fan motor you can try a hair dryer to defrost the ice out of it.
2helpful
2answers
Buzzing after 1 hour
Is the buzzing coming from the back of the TV, staying loud even when the volume is turned all the way down, or is it coming from the speakers?
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
