Tries to boot goes to a black screen that says I should start it in safe mode if this and normal mode if that... then tries again and flashes a blue screen for like a 10th of a second and goes back to the same black screen.
Tech guys at school said the hard drive failed but obviously can't take it apart to check... now what?
Unplugg any external device and restart the computer. If still not, Click on F2 as soon as the computer restarts.. It will open BIOS, press F9 & then F10. Restart the computer.
I have an acer asprire 6920 and i go to start up the laptop and it showes the logo screen then asks if i want to start in safe mode and then thinks for a while and then screen goes black with just mouse showing. What do I do?
Depending on your version of windows, I would trying starting in safe mode to see if the computer does boot. If it does, then you want to restart again, go to advanced boot options and select "start windows with last known good configuration." Access advanced boot options following the steps at this link. Need to Start Windows 7 in Safe Mode Here How
Restart the Acer Aspire netbook by pressing the "power" button on the netbook's keyboard or by pressing the "CTRL," "ALT" and "DEL" keys at the same time.
During startup, hold down the "F8" function key immediately when you see the "Acer" splash screen and the option for entering "Setup."
Keep pressing the "F8" key until the "Advanced Boot Options" menu appears. If you receive a "keyboard error," restart the Acer Aspire and repeat step 2.
Use the arrow keys to navigate to the "Safe Mode" selection on the "Advanced Boot Options" menu. The arrow keys are located on the right-hand side of the Acer Aspire keyboard.
5
Press the "Enter" key to execute the "Safe Mode" selection. The Windows operating system will now start in "Safe Mode" and you can perform a system restore or make needed changes to get your Acer Aspire to boot normally again.
Read more: How to Boot Up Acer Aspire in Safe Mode ' eHow.com http://www.ehow.com/how_5802430_boot-acer-aspire-safe-mode.html#ixzz1dtOxfxaD
Go to task manager and try killing explorer.exe and try restarting the same
Take the system to safemode and do a clean boot
try removing unwanted startup items
Try booting into safe mode first. During boot up press F8 a few times, you should get a safe mode menu to; start windows normal, or safe mode, chose safe mode an see if that will get you logged in.
you have a corrupted operating system, please restore the laptop by pressing Alt+F10 immediately after pressing the power button and follow the screen.
So in that case you need to reinstall the Windows so that it will fix the problem. Some instances of that problem corrupted Operating System it needs a new copy.
try to go to safe mode first, after that, shut it down and reboot to normal mode, usually it will work.
If it don't work, go to safe mode and move your files/data to d partition and after that reload using alt+F10
