Why is the picture dimming. Not bright enough. Is the lamp going out?
It does sound like your lamp is going out. this happens after 2.5-5 years depending on the tv and amount of use. You can find cheap replacments and sometimes can get them a discount if you buy 2.
comment if you need sites or info on replaments
Testimonial: "Thank you for answering my question. Have to find the right bulb for my tv now.."
Here are a few sites to get you can check:
http://www.purelandsupply.com
http://www.lcdprojectorlamp.net/
http://www.topbulb.com/
I can't recomend one over the other because When I had to replace a Bulb a friend of mine worked for a home-theater comany In California. We did the work so it was not so much. It is not hard to do. Let me know if you have any questions on how to install it.
It's the lamp, when I finally had to replace mine I couldn't believe how bright it was. This is a very easy replacement to do, 10-15 minutes and its done.
BTW, the more you run it on Dynamic Mode the faster the bulb goes bad.
A TV HAS LARGE LIFE TIME.DON PERLACE IT IMMEDIATELY.CHECK DISPLAY SETTINGS.
