Nikon D70 Digital Camera with 18-50mm Lens Logo
Posted on Mar 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Nikon D70 batteries discharging too quickly - Nikon D70 Digital Camera with 18-50mm Lens
pictureman4u
Level 2:
  • Expert 132 Answers
  • Posted on Mar 26, 2010
pictureman4u
Expert
Level 2:
Answers
132
Questions
0
Helped
43954
Points
329
Try switching to the EN-EL3 EN-EL3a 1500mAh Li-Ion Battery for Nikon D70..or a 1800mAh.
1helpful
Camera will not power up changed battery just went dead Nikon D70
Fixing a Dead Nikon D70 - Green Blinking Light My first-generation Nikon D70, which I bought the day it was released to the market a few years back, died on me a few months ago. Without a card in it, it won't start, and when you insert a CF card in the slot, the green data-access indicator flashes on and off. If I hold down the Menu button, the menu flashes on and off along with the green LED.
d70_87x1.jpgAs it turns out, this is a known problem with the original Nikon D70 cameras, and Nikon USA has a service bulletin out on the camera body. They'll repair it free of charge.
So, if you have the same problem, visit this service bulletin page, http://nikonusa.com/Service-And-Support/Service-Advisories/D70-Service-Advisory.page click on the D70, and you can access a PDF file that you'll need to print, fill out and send to Nikon along with your camera body. Be sure to take your camera strap off and remove the battery, and don't send any lenses or other accessories.
Mine's on it's way to Nikon now - they say the turnaround is five days (plus shipping time).
1helpful
2answers
Nikon D70 On/Off switch will not turn the camera off.
Hi, The problem with your camera is the power switch under the top cover needs to be repaired Or replaced by a camera repair tec, I have repaired this problem many times, Not a quick fix.
D70 put full charged battery in, within a few seconds goes dead
Nancy,
How old is this battery? They do indeed wear out. The best way to tell is to put ii in the charger. If it charges up way too quickly, then the battery is shot.
CAMERA WILL NOT SWITCH ON NIKON D70S
http://nikonsro.com/email_images/nikonusa/service_advisory/d70.html
Is this your problem? If so, Nikon will repair it for free, even if it's out of warantee. :)
P.S. Please stop "shouting!" (Turn off caps lock!)
Nikon d70 not showing shots in order as when i take them.
Camera uses time/date stamp of file to determine order, are these correct or do they show incorrect time? If not, then internal lithium battery needs replaced.
Nikon d70 camera
switch off the camera.Remove the battery from the camera,after two minutes reload the battery.Switch on ok?
If not, using the reset option you can correct it.
If not, if you have warranty leave it with seller
Nikon D70 (Control Panel.)
This is a known problem that is being repaired FREE of charge by Nikon. Go here for a form to fill out: http://www.nikonusa.com/email_images/nikonusa/service_advisory/d70.html
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
