KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
Posted on Mar 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It seams to automaticly self defrost, draining into the trat below.
Cool Blue Services
Level 3:
  • Master 560 Answers
  • Posted on Mar 17, 2010
Cool Blue Services
Master
Level 3:
Answers
560
Questions
0
Helped
225166
Points
1573
Your refrigerator is supposed to defrost automatically, usually every six to eight hours depending on the type of defrost relay timer you have. Most timers are either six or eight hour. this is a normal condition.
Water leaking on the floor during automatic defrosting.
The drain on the back is blocked. You should find a small plastic P-Trap just below the freezer. Remove it, soak in bleach and hot water for 30 minutes, rinse and shake clear.
Google
make model clean defrost drain
Please always include full 'make model (what it is)' as the first three words in every question.
I hear water running into a tray on the floor, it went on for several minutes. Is this a function of the self-defrost?
water from defrost cycle does drain to a pan below.if water is'nt ending up on floor it is probably normal operation
4helpful
Our freezer bottom gets filled with ice, we dont have an ice maker, we defrost it and within a month the bottom has a ice on it so we cant even putt the basket out
You have a drain that is freezing up. Pull the cover off the bottom back inside the freezer and bend the heat element down closer to the aliminum drain tray. It is too far away to heat the aliminum trat. The element is black and it is below the evaporator coil which has fins on it.
2helpful
2answers
Coils freezing over inside a side by side
Most times when coils freeze up it is due to the failure of the automatic defrost circuit, specifically either the defrost thermostat or the defrost timer. Occasionally it is the drain under the coils somehow gets clogged and the water from the defrost cycle doesn't drain. If you have water in the fridge side or water forming ice outside the back panel in the freezer the defrost is probly working and the drain is clogged. YOU MUST GET ALL THE ICE OUT OF THE DRAIN. Hair dryer, hot water, etc must be applied. Water MUST flow freely to the drain pan below.
Water leaking onto floor when defrosting automatically
There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are cased by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
[email protected]
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
SEA BREEZE TIP's
2helpful
Defroster drain leaks into the main compartment
The drain hole is plugged. Probably with ice now. Needs to be fully defrosted with a heat gun or hairdryer, be sure drain is free by pouring hot water into it and seeing it get to the pan below the machine. If this persists you need to troubleshoot the automatic defrost circuit. Could be bad defrost timer.
1helpful
I have a top freezer/refrigerator and notice that ice is accumulating in the freezer and underneath the freezer in the fridge. What are my settings supposed to be set at? What should I do?
It sounds as if your refrigerator has stopped automatic defrosting of the evaporator coil or has a plugged defrost drain.. Below is some information provided by: www.repairclinic.com, to help you understand what may be wrong with your unit. If it is not cooling properly, you may be able to get it cooling again, temporarily by removing all perishable items, unplugging the unit, and allowing it to stand idle wth the doors open. This will allow the ice to melt, which will allow air flow to resume normally through the unit. Allow several hours for the ice to thaw completely, then close the doors and return it to an operational status. Put water in both compartments and when satisfied with the results of temperature, i.e. frozen in freezer and cold in fresh food compartment, you can put perishables back in. This will allow normal operation for only about a week until the defective part gets replaced, then it will start warming up again.
If the drain is plugged then the diagrams should show the routing so you can clean it out.
Today, all but the smaller, apartment-sized refrigerators are self-defrosting. Self-defrosting means what it implies--though frost continues to accumulate inside the refrigerator, it melts automatically. The self-defrosting system has three functional components:
Defrost timer
Defrost heater
Defrost thermostat.
Defrost timer The timer is like a clock. It continually advances, 24 hours a day. Every 6 to 8 hours, the timer turns off the cooling system of the refrigerator and turns on the defrost heater.
Defrost heater The defrost heater is similar to the burners on an electric stove. It's located just beneath the cooling coils, which are concealed behind a panel in the freezer compartment. The heater gets hot. And, because it's close to the cooling coils, any ice or frost build-up melts.
As the frost and ice melt, the resulting water drips into a trough. The trough is connected to a tube that drains the water into a shallow pan at the bottom of the refrigerator. The water is then evaporated by a fan that blows warm air from the compressor motor over the pan and out the front of the refrigerator.
Defrost thermostat The process ends after either the amount of time specified on the timer or when the defrost thermostat near the cooling coils senses that the heat near the coils has reached a specific temperature.
Detailed parts diagram:
http://www.repairclinic.com/Refrigerator-Freezer-On-Top-Appliance-Diagram
2answers
Maytag Freezer mqu1556aew 2004-07.Ice buiding up on the bottom of freezer.
if self defrosting model check frozen drain in freezer
Aug 09, 2009 • Freezers
Top KitchenAid Refrigerators Experts
vince
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
