SOURCE: can't install printmastersilver12 ''cannot determing configuration
where is there main website or what are the requirements for this application - was it designed for windows 98 or what exactly ??
SOURCE: How to configure Printmaster 12
melodie roba,
Most definitely this could be your problem! I would reccomend that you completely uninstall Printmaster 12, run another virus check, then reinstall the program. Once the program is installed, update it through the vendor and it should work fine. You should be able to find the vendor (PrintMaster) updates through the help menus.
Hope this helps,
-samson39
SOURCE: I recently had my computer serviced for a major
May have to uninstall it first, then reinstall it.
Click START button, lower left corner
then click Control panel
then click on add or remove programs
*see if your product is listed(may be under BRODERBUND or other publisher name)
If it IS listed, uninstall it
Or sometimes the UNINSTALL is included in the CD options:
Insert the cd into the drive
go to my computer
find the cd drive
right-click the drive
select "explore"
Look for an Uninstall program
Hope this helps!
hansola
SOURCE: I have a error message when trying to open printmaster platinum 12
Use window search find the file and delete I did what was at support and it did not work I found this file in all users folder deleted it and all is well
SOURCE: I have the printmaster platinum 15. When I try to
I would use REVO Uninstaller to remove it completely from your system, this uninstallation utility works like a charm and completely "nukes" it off the system so to speak, better than the regular uninstaller can even dream of :). Get it for free from:
http://www.revouninstaller.com/revo_uninstaller_free_download.html
Make sure you download the one under FREEWARE, not the one they want you to pay for.
Install that, open it up and find the Print Master on the list, and go to uninstall / remove. Walk through the process and you should be good to go.
If it doesn't work, please let me know
Tim
