When the printer is powered on it the print cartridge slam from one side to another. Then display message on screen about obstruction with printer error 1200.
Why The Dell Printer Offline Error Occurs?
§There can be issues with Printers and Devices in the control panel thereby leading to the problem at hand.
§There can be issues with the Printer Settings resulting in the particular error.
§Issues with the Printer Driver can also cause this Dell-related error code.
§There can be some connectivity issues with your Router or Modem that are probable causes of the Printer Offline error code.
§Issues with hardware and software can also prevail thereby causing several printer errors repeatedly.
§Communication issues, resulting from Antivirus or incorrect Firewall settings.
§Incorrect IP Address sometimes results in such issues.
For More Info Do Visit Us: Dell printer offline
Or You Can Call Us: +1-888-633-7151
Hi there
Ok you can try this.
Error code: 1200
This error code is commonly associated with the Dell 922 printer. Usually you might see the cartridge moving front and back and slamming itself against the printer. You need to tighten the strings located on the back of the printer and then it should work fine
Clean the carriage rail. This is the round chrome piece that the carriage assy that holds the cartridges rides on. Use a paper towel that is slightly moist.
Be sure to not force anything. Unplug the printer after you get the carts in the middle. Move them to one side and clean and then move them to the other and repeat.
Lift up the scanner to reveal the cartridge compartment; under the chrome rod on which the cartridges run there are two small gaps about 8cm apart. In the right one should sit the paper sensor which is a small black rod that hooks downwards; the problem I had was my sensor had bent up and out of the gap so all I had to do was bend it gently back into position using a small screwdriver.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
