1985 gmc vandura 2500 will not fire when trying to start but will fire one time when you turn switch off
See my answer above to the other fella's computer question. My guess is it will die, and if you turn off the key, it will restart and run okay, or run okay for awhile and do it again. Bypass the spark control module and computer. The computer is the cause of your problem, and it whacks the sparkcontrol module hen it goes. The computer is behind the dash on the passenger side, and you have to pull the dash to get to it. It is expensive as hell, and it will burn out again if it does it once- take my word for it. best option is find a mechanic who can help you clip the wires to both units and bypass them They are color-coded and it is easy to do. You will lose about 5 mpg mileage (more if you change altitude a lot), but it's worth it. Spark control module costs about $100 (10 years ago) and the computer costs about $2,000. Dealer will charge $2400 + labor to change the computer, because it is a ***** to get to!
Sounds like you may have problems with the ignition switch. The starter is turning over? But the motor doesn't fire, until you turn the key off?
