Baby Gear Logo
Posted on Mar 10, 2008
Sharp Atomic Clock Daylight Savings
My Sharp Atomic Clock doesn't seem to want to change for Daylight Savings. My other Atomic Clock changes just fine so I know I'm getting a signal. Any Idea how I can do this manually? I can't seem to find it by going through all the buttons on the back.
Thanks.
Tina
  • 9 more comments
  • Greg Tee Mar 12, 2008
    We just experienced the same thing: clock apparently not aware of recent changes to daylight savings schedule, instruction manual gone missing. As with any modern electronic gizmo, the first step is to try removing and reinstalling the batteries (a "cold boot", in computerese). No luck this time. So I tried again, this time pressing the little MT button on the back for mountain time, instead of PT for pacific time. Now the clock has advanced an hour. Its a work-around, and if the clock later decides to make the daylight time adjustment, we will have to revert to pacific time. If you are in the eastern time zone, I can't help ya.
  • diane6246 Jul 06, 2008
    need to reset to daylight savings time
  • Anonymous Mar 09, 2009
    Clock resets on the old DST dates fall and spring. How do I get it to reset on the new dates?
  • Anonymous Mar 10, 2009
    Can not start my Sharp Atomic Clock.
  • Anonymous Mar 12, 2009
    Sharp atomic clock won't reset to daylight savings, took out battery and now it isn't running at all!
  • abuyer2 Mar 13, 2009
    The Sharp Atomic clock resets only using the old time savings schedule. You'll see that in two or three weeks it will change time. The only way to fix this is by updating whatever "programming" the clock has inside. The clock is probably too cheap for Sharp to bother making any change available.
  • Anonymous Mar 16, 2009
    Exactly the same as the previous one. My Sharp WWVB seems to have no way to turn daylight savings time on or off. On the back there are 4 time zone buttons, a smaller button with no markings and a 'reset' button.
  • mrbillbenson Apr 12, 2009
    I have a somewhat large clock, and it also has the 3 buttons for time zones in the back. I had no idea what the leverage button was until someone described it to me. Seems if you depress it slightly, the second hand moves, and if firmer (all the way in) the minute hand spins. Had I know this life would have been a lot easier. but my wife bought the clock and no one knew where the directions were. thanks so much to the original person who answered how to get this things working again.
    Bless you!
  • Anonymous Apr 13, 2009
    I have read the posts. We're past ALL day light saving's times dates. I tried the reset button. Our clock went to 12:00 for a few minutes and then started running at the update signal and went to standard time again. Clearly, the satellite hasn't been updated. So, what are we to do? The last time that time changed, we only had to wait for the original time change, and our clock corrected itself as someone else said it would, but this time, we have no such luck. Any suggestions?
  • Anonymous Apr 24, 2009
    I need to change the time zone, and I cant't find the book.
  • david cohen
    david cohen Jul 22, 2014
    i have a sharp spc373 atomic clock for which i have lost instructions. i cant seem to move it from pacific time to eastern daylight savings. any ideas?
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 10, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
23101
Points
8
I have misplaced the manual for my sharp Atomic clock, need to reset the time zone and shut off the alarm. How can I obtain a new manual?
Anonymous
Level 1:
New Friend:
  • Posted on Nov 01, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
23101
Points
8
I have the Sharp digital atomic clock, model SPC373. I bought it at a thrift store for a few bucks and don't have the manual. This morning (11/1/2009) it was still reading DST and hadn't set itself back an hour, so I pushed the "receive" button on the back. The little satellite dish icon did its animation thing (like it's receiving a signal) and after a couple of minutes, it reset itself to the correct time. In my opinion, DST is ridiculous and causes more trouble than it's worth! Half the world doesn't even bother with DST! Now that we have this "atomic clock" technology, maybe the worldwide department of standards can come up with a clock that just drops or adds a couple of minutes throughout the year to achieve the same effect as DST without drastically disrupting our circadian rhythm twice a year! (Similar to what they did in ancient times.) Or maybe we can just live with the fact that the sunrise and sunset, shifts throughout the year and not make such a big deal over it! The "developed world" only just started doing this DST thing in the beginning of the 20th century, it's really a new invention by historical standards. There is an interesting Wikipedia article about DST...check it out. (And good luck with your "modern technology" clock!)
Anonymous
Level 1:
  • Posted on May 10, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
23101
Points
9
I put fresh battery in and the clock set itself to 12:00, I didn't touch anything, and it stayed in that mode until it set itself by radio signal during the night.
The following morning the clock appeared to be set for Pacific Time, I pushed the "E T" button on the back, and the clock set itself to eastern daylight savings time by itself.
A
Anonymous
17 of 17 people found the following review helpful: Sharp Atomic Clock Daylight Savings - stars-2-0._v47081858_.gif Fix for 2007 daylight savings time, March 28, 2007 By Norman Geimer (West Coast, USA) - See all my reviews
c7y_badge_rn_1._v47060296_.gif I called Sharp Electronics (about the failure of the clock to detect the new 2007 daylight savings time), and it turns out Sharp Electronics is a different company then Sharp who sell/support the atomic clock. I got the number for this company and these are the instructions for updating the clock's time (should work in any time zone).
1) Pull the batteries and wait a few minutes.
2) Put batteries back in - time will set to 8:00 (or possibly something different).
3) Press the "leverage button" (just above an to the left of the time zone buttons) and the clock hands will spin.
4) Release the leverage button when the correct time is reached.
5) Supposedly, this new time will track correctly and keep accurate time.
I asked what would happen next fall, and they said if if didn't track correct, steps 1 and 2 above should be sufficient.
Hope this helps - not the greatest time piece to be sure.
1helpful
I lost the instructions for the talking Reizen atomic clock and both of them are now an hour off. How do I reset the time?
You need to change the 'Zone' settings on both; the signal from Boulder, CO can't tell where you are, you have to make the correction locally and then they will track the signal accurately as long as they can receive it.
4helpful
2answers
I have a radio Shack Atomic Wall Clock 63-1438 and the time didn't change on Oct 31, 2009. Should it automatically change of do I have to reset the clock?
Most atomic clocks simply receive the National Institute of Standards and Technology (NIST) time signal. They do not all allow for daylight savings time changes as not all areas use it.
You will have to adjust manually.
3helpful
My SIO/SCAN 31420E did not reset for daylight savings time and I can't find the instructions to reset
how do I change my atomic clock to eastern time zone. Or when I set my time does it automatically set to the correct time zone.
1helpful
Your clock may need to receive a signal indicating the time change. You can try moving it to another room, or outside to see if it reads the signal. Mine didn't, so I removed the battery and reset the clock. It wasn't obvious how to do that and I didn't save the owner's manual but upon close inspection there was a tiny black button (that looks like where you would lift a cover for a battery) and pressing it allowed me to adjust to the correct time. It is a "Sharp" bought at Target a couple of years ago.
2answers
RCA atomic clock radio didn't reset to DST
Perhaps you've already tried this but on my atomic clock I have to select the DST option and make sure you're in the correct time zone.
Atomic clock
There is a setting on the clock to turn on "DST"- daylight savings time feature. You have to push the set button on the back of the clock repeatedly until you see "DST" blinking. You should also see "OFF" blinking at that point indicating that the feature if turned off. If you now push "+" button on the back of the clock once it should show "ON" blinking instead of "OFF". Hope this helps.
FixerUpper
2answers
Daylight savings time
so long as the US atomic clock adjusts their daylight saving times then you should be fine check this link for some more details (about the scr 110 but seems to be basically the same) http://www.amazon.com/H-H-Scott-SCR110-Atomic-Clock/dp/B00004TZDN/ref=sr_1_2/104-1966292-9407907?ie=UTF8&s=electronics&qid=1173502881&sr=1-2 hope this helps :)
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Baby Gear Expert? Answer questions, earn points and help others
