Sony Playstation 3 (PS3) Console Logo
Posted on Mar 16, 2010
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red light stops flashing and is just a solid red if I touch the power buttom again its just more of the same. It is a fat ps3 40gb
Anonymous
Level 1:
New Friend:
  • Contributor 28 Answers
  • Posted on Mar 16, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
28
Questions
0
Helped
7629
Points
55
This happens when the ps3 has overheated-try removing the hard drive and replacing then give the console a hoover out.....if this doesnt work try holding the power button on for 5 sec....if this doesnt work its back to sony im affraid
1 Related Answer
Anonymous
  • 378 Answers
  • Posted on May 10, 2010
SOURCE: I turn on my ps3 and the green light comes on for
It needs to have the chips reflowed. We are a listed repair service on this site and we offer the repair for $59.99.
www.videogamerepairservice.com
1helpful
Ps3 turns on then turns off and beeps three times
Sounds like a power supply issue. Unless it is showing any other colours after the green light. Red would be ylod which means a phone call to Sony. Try a new power supply and see if that fixes it.
I turn on my ps3 and the green light comes on for a short time and the it beeps three times shuts off and the green light turns red and starts to flash. If I push the power button again the red Light
you need to change your power box there is a bad connection with the wires. its over heating you might whant to buy another at game stop or take it in to get fixed. the more you messed with it it might mess up your whole system.
1helpful
My PS3 occasionally starts up properly, but usually the power indicator light flashes yellow and green for a short time and then beeps three times and flashes red until i turn it off by holding the power...
Hi tristan,
The PS3 red light is a huge problem and it is caused by the GPU and the CPU overheating, all you need to do is stop the heat build up.
You have 2 ways of doing this:
You can send it in however bear in mind that for the fix you will have to wait for 4 weeks and also pay out $150 as well.
Or you can use a good PS3 Repair guide to fix the problem.
Make sure you check out these reviews of the top PS3 Repair guides first!
Cheers!
2helpful
When I turn on my ps3 model cechg01, it blinks the green light a couple times then shuts itself off. No other color lights just the green one, then beeps three times and shuts off.. Can anybody help narrow...
When you plug in your system with the power cable and turn the toggle switch (in the back) do you see the red stand by light?
The red and yellow light comes from 1 bulb and the green and blu light comes from another..
If you have the YLOD and your yellow/red light is out, you will only see the green light.
I am really interested in your problem.
Do this to check your status: If you can do this function below but not any other, chances are, you do have the YLOD. It can be fixed.
Power off the unit using the toggle switch on the back. Hold down the 'eject' button and turn the toggle switch back from off to on. This will run a fan test and should eject your disc. Remember, this will only work on the 20, 40g models. Not the backwards compatible units with the 4 usb port holes and the memory card slots.
After pressing the on button it turns green for 5 seconds then it flashes yellow/orange for a second then it flashes red.
Yellow Light of DeathThe "Yellow Light of Death" or YLOD is the common phrase people use to describe the following sequence when they try to turn on their PS3:
  • Press Power Button
  • Red Light Flashes Three Times
  • Yellow Light Flashes
  • Green Light Flashes
  • Beeps Three Times
  • Red Light Flashes
The sequence above may vary a bit but you do see the flashing yellow light (sometimes shows up as orange) that normally you would not see when operating your PS3. The YLOD is a general hardware fault that can mean a lot of things. However, one of the problems is cracked solder that leads the PS3 to think one of its internal chips is not connected or is broken somehow. Cracked solder can happen when the chips get too hot (RSX most likely) and leads the motherboard to start bending, which may crack the solder. Changing the power supply (lower the average wattage going to the chips to lower the heat) and better thermal compound (heat dissipates faster to the heatsink) may prevent this error from occurring. However, if your PS3 has already had the YLOD, then you can reflow your motherboard every few months to keep it working (but it is not a permanent fix as the YLOD usually comes back).
My ps3 suddenely turned itself off mid-game. turned it back onto standby mode, then when i turned it on the light went green as normal then suddenely red light came on with the green, three rapid beeps...
try this:
it works for slimline PS2. might work for PS3.
1) turn off PS3
2) unplug PS3 and wait a minute or two before plugging back in.
3) turn on PS3
hope this helps.
it could also be overheating.
1helpful
My ps3 wont turn on
HI, the power supply is unstable or weak. you will need to replace this failing power supply soon. it is damaged.
Power problem with ps3
I think your ps3 is toast. i have same problem and been searching online and have also asked on this site and they said it was toast
1helpful
2answers
PS3 not working
Good News! PS3 got red light blinking and beeps can be fixed by yourself! With the all-in-one PS3 Repair Package - You will learn the techniques and knowledges to repair your PS3 including motherboard problem, hard disk problem, blu-ray drive errors and much more. Get one copy and secure your PS3 now.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
