After hours of internet searching, thank God I found you guys. I COULD NOT GET THE BIT OFF! After following your advice (just tap it) it EASILY came out. Thank you thank you thank you!!!After hours of internet searching, thank God I found you guys. I COULD NOT GET THE BIT OFF! After following your advice (just tap it) it EASILY came out. Thank you thank you thank you!!!
You can't post conmments that contain an email address.
this website is directly from dremel. It shows different projects, crafts, or hobbies you can use it for. It is a real simple tool to use, and also is very handy. You can obtain several types of bits for it ones for sanding, engrving, cutting all types of materials, and much much more. Hope this helps
Push the pin on the side next to the tip and hold it while Your wrench is turning the hex shaped piece around the bit that is what is holding your bit in. this should help as i am a proud owner of a Dremel. Hope this helps . if you have any further questions write back.
