I have my dometic Rooftop AC unit. The heatstrip/fan run perfectly but when I turn on the AC...the fan runs good but when the compressor kicks on, it just hums.
Bad run capacitor or bad compressor. If you hear an occasional click from the compressor try a new run cap and then a hard start kit. Otherwise it's more economical to purchase a new unit.
WHEN A COMPRESSOR FIRST STARTS TO RUN THERE IS AN INITIAL HIGH STARTING CURRENT(30 AMPS PLUS),BUT THIS SHOULD DROP BACK DOWN TO RUNNING CURRENT PRETTY QUICKLY.IF IT MAINTAINS THIS HIGH STARTING CURRENT FOR A WHILE THEN THIS GENERALLY INDICATES THE COMPRESSOR AT FAULT,BUT!!!!! ALSO CHECK TO SEE IF THE FAN IS NOT SEIZED. DISCONNECT THE FAN ELECTRICALLY THEN RUN THE UNIT. IF THE STARTING CURRENT MAINTAINS APPROX 6 AMPS THEN THE FAN IS AT FAULT!........HOPE THIS HELPS!!
REGARDS........BIGGGAZZ
If the compressor is running with no cold air the unit is more than likely no good. It can not be recharged. you need a new unit. If the compressor is not running you need to check the capacitors.
If the compressor never kicks in, I would check the start capacitor, thermostat and the compressor windings. Most times the start capacitor is defective. Some window air conditioners the fan will run while the compressor stop through the thermostat switch. If the thermostat switch is bad every thing runs except the compressor. Let me know, Thanks, Sea Breeze
Sounds like a power supply problem. There is enough power to run the fan but when you turn it to cool the current draw by the compressor drops the voltage. The lower power light is telling you the answer to your problem.
I suspect that you have a bad selector switch for the on, off, low fan, high fan operation. If the selector switch is put into the off position everything should stop completely.
