Hello friend, It seems that your Outlook profile has
been corrupted severely so you are unable to use inbox repair tool for Windows 7. Don't worry; you can solve this
problem by making use of Outlook repair tool which will really help you to
repair your Outlook as it did to me. You can download this tool simply by
clicking here. Good luck, Senorita Brown
If you are facing such type of any problem then you can take help from inbuilt utility tool that is Scanpst.exe. This toll may helps you to solve your outlook problem. If this tool fails to Fix the pst problem then you can take help from here.
http://www.microsoftoutlookrepair.biz
Inbox repair tool(scanpst) is the best tool that can be used when you are finding any difficulties to connect your inbox folders or pst files or it is reporting that your Inbox folders or Outlook PST file may be damaged in Microsoft Office Outlook 2000 (or higher).Scanpst is a tiny tool installed by default when installing Microsoft Office 2000 or higher.
PST files or Personal Folder Files are used by Microsoft Outlook for storing Outlook data, including mailbox files, email folders, contacts or any other personal data related to Microsoft Outlook.
see the step by step instruction here
http://soluzia.net/How-to-repair-Outlook-folders-using-the-Inbox-Repair-Tool.php
Method 2:
Try to open Outlook without addins.
1.Click on start button and click on Run.
2.Type outlook.exe /a and press enter.
If he can open Outlook in this way, then the third party addins are causing the issue. This can be resolved by
removing the third party addins. Follow these steps to remove third party addins.
1.Open Outlok and click On the Tools menu, click Trust Center, and then click Add-ins.(for Office 2007).
2.In the Add-ins box, identify the add-in that you want to disable and note the Add-in type located in the Type
column.
3.Select the Add-in type in the Manage box and then click Go.
4.clear the check box for the Add-in that you want to disable and then click OK.
Method3:
Press Cntrl+Alt+Delete to open task manager and click on processes. click on outlook.exe and click on End process.
If there is multiple outlook.exe running end all of them. Try to open outlook after ending all outlook.exe processes.
Method4:
Take a back up of pst files and reinstall Outlook . follow these steps to take a backup of pst files.
1.Close any messaging programs such as Outlook, Microsoft Exchange, or Microsoft Windows Messaging.
2.Click on start button and go to setting and open control panel.
3.Double-click the Mail icon.
4.Click Show Profiles.
5.Click the appropriate profile, and then click Properties.
6.Click Data Files.
7.Under Name, click the Personal Folders Service that you want to back up. By default, this service is called Personal 8.Folders. However,
it may be named something else
9.Click Settings, and then note the path and file name that appears.
10.Close all the Properties windows.
11.Open the file through the path and copy it to a new folder as backup.
