Hi. If you remove the light unit ond the lower casing which has four screws two of which are under the small vent covers that unclip. The light unit by the way has two screws under the difuser and that unclips. Mark the top before removeing with tape to give ease of replacement. After removing the top light unit inside the fridge and unclipping the two electrical terminals it can be removed. The same is true for the lower unit. Be aware the lower unit will be frozen in place. Ease it away to break the ice seal and remove the electrical connections. Use a hairdrier on full powar to fefrost the cooler unit at the rear of the fridge. Use the same method to defrost the removed fan unit. Pay attention to the fan drain. It may need the insulation trimming to make it drain and work again when re installed. Cut it away with a craft knife. When it is dry and defrosted re install in using the reverse procedure. Be aware it will frost up again and need you to do the whole thing again as soon as the fan gives signs of fouling on ice. You will hear it catch. Regards. Paul.
