SOURCE: Xerox Phaser 7750DN FUSER JAM
Are you getting a specific code? 10-XXX ?? That would help narrow it down.
SOURCE: xerox phaser 6120 laser printer paper jam fuser
You can remove the imaging unit, then
Depending on the stock being used for the job, raise or lower the left and right colored Fuser separator levers. The levers will stay in the raised or lowered position on their own.
the levers are green. The fuser itself is not easy to remove.
Do you have any warranty left on the machine? Or a depot repair agreement?
SOURCE: paper jam
I had the same problem kept getting an error something like Jam at Exit Door Open Door A. When I looked at the top of the where paper normally comes from and flipped it open I found a super crinkled piece of paper, which once removed cleared the jam.
SOURCE: Color Printer Xerox Phaser 6180 Black Background Print out
Try the link below. If the toner is leaking from the cartridge return it to shop were you got it if it is damaged.
http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=466,E=0000000001344030351,K=1906,Sxi=11,Case=obj(1307)
Niallbt
SOURCE: I have a xerox phaser 3124 which have a paper jam
Xerox printers have known issues with the rollers. You may want to look into getting some new rollers, they're not that expensive. I think with this model there's one in the tray, and one up above where the paper enters the printer.
