Zenith B25A10Z 25" TV Logo
Posted on Mar 16, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Zenith TV has me seeing red.
The picture on my Zenith B25A10Z is only shades of red. Adjusting the color did nothing to help. Adjusting the tint only brightened or dimmed the image on the screen. What else could I do to fix this?
Anonymous
Level 3:
  • Master 410 Answers
  • Posted on Mar 16, 2010
Anonymous
Master
Level 3:
Answers
410
Questions
0
Helped
157417
Points
1326
The red gun in the picture tube itself is shorted on. You will have to replace the picture tube itself to fix the problem. Probably want to just buy a new set. Sorry!
Picture has red tint
I would unplug it from the wall for a while and see if that will help reset it. Also make sure there are no magnetic devices near the screen because this will change the screen color as well. Mine will mess up every once in a while so I just unplug it while I am off running errands, plug it back up when I come home and it seems to reset itself. Good luck
3answers
F31672et rca tv
Is this a projection/plasma/CRT?
57 inch hdmi rear projection no green or red in picture
how do i press tint on remote dont know how to get in
Problems with B25A10Z Zenith 25" tv
that model has had a few different problems that cause this. bad micro,bad regulator,bad caps and tuner shorts. suggest you take to the shop for an estimate
My zenith b25a10z tv has no color...can it be fixed?
main ic is bad, as I remember it starts with TA
Screen is all Shades of Red....
You need to remove the front tv panel, search for the screws right behind the screen and speaker area on the sides of tv. Should be four of them, carefully remove the lower have/quarter and you will find a control box, 6 knobs. Try adjusting them to clear the problem, each color has its own knob, be sure to mark their original position befor adjusting. When you find the red adjustment knob, you should be able to turn it down enough so that it doesnt overpower the rest of the colors. Good luck.
Zenith B25A10Z connected to a DVD player via modulator. We use verzon STB. Dvd will not display on TV when turned on. Remote a/v does nothing. Any help?
If you are using a modulator, usually that sends a signal to channel 3 or 4. Select either 3 or 4 and you should get the signal. The modulator should have a switch to enable you to select one of those channels. Selecting the Video input is when the DVD is connected using the audio and video cables (Red/White/Yellow)
Dan
Picture is mostly red
might try to grayscale but that usually means taking the back off and making the adjustments
TV Problem
picture is milky white is due to crt.if it is old set. or check video section
1helpful
2answers
Sanyo Tv color problem
I would check the green signal all the wat to the display screen to determine is this is a signal problem or a system short. I would recommend that you take this set to a qualified electronics technician
Top Zenith Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
