Please clarify you issue. Does the lens stick? Does is refuse to retract? does it switch off?
If it switches off Try the following if any other listed faults a repair is needed:
Make sure that you are installing a fresh/ full charge battery
Remove the memory card and the battery
Clean the metal contacts on the battery using a clean cloth
Use the camera w/o the memory card
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
i dropped my camera and now da lens dont function right......my camera takes blurry pictures now and the lenses are makin a clickin sound......i have tried to resolve this problem by checkin the FOCUS, the MP, the ISO SPEED, i mainly tried everything and my camera still take blurry pictures.
The Camera dropped and when i tried to put it off the lense refused to retract eversince it has been stuck out. Infact it doesnt work again at all. Sometimes it comes on but it goes back to blank nevertheless the lens still doesnt retract at all. I have been charging the battery ever since but still it doesnt come on.
We are having the same problem the lens will not retract and everything is blurry through view finder. How do we get this camera repaired
lens won't open or close all the way.
Lens wont open or close
i dropped me camera and now theres a dent in the lens. it wont retract
I'm not aware of my camera being dropped or otherwise jostled, but the lens wont emerge and the shutter wont fully open. I've tried charging it the battery is fully charged. After it sat for a couple of months, it opened and I took a couple of pictures, now it wont open again.
I'm not sure how it happened, but the lens came out of the track while it was extended and the lens would not close back into the camera
