My Compaq presario CQ50 is having trouble connecting to the internet. It's always connected to the same router and it worked perfectly this morning. The problem might be in my laptop since I can still go to the internet on my mom's laptop(same room and distance away from router). The wifi button is blue not orange/red and it says that the connection to the router is successful but whenever I try to go to a website, "the webpage is not available" or "server not found" appears.
Run windows diagnostics and if that doesnt work, open up the command prompt in administrator mode and type in /ipconfig renew and after that type in /ipconfig repair and see if that helps. Also look in internet options and under connections click on lan and check that there are no numbers in the proxy box as this can sometimes cause issues if you have used any software to hide your ip address.
