Oregon Scientific Oregon Chainsaw chain for Stihl Chainsaw 20" Bar Length 72 Drive links 3/8 Standard 0.05 Gauge Chiesel Chain Logo
Posted on Mar 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Doesn't stay running
Stahl chain saw doesn't stay running wondering if there are any basic ajustments to start with
Anonymous
Level 3:
President:
  • Master 2,220 Answers
  • Posted on Mar 16, 2010
Anonymous
Master
Level 3:
President:
Answers
2220
Questions
Helped
1383912
Points
7625
Stihls carbon foul mufflers more often than any other brand. Clean it and the spark arrestor.
Anonymous
Level 2:
  • Expert 111 Answers
Anonymous
Expert
Level 2:
Answers
111
Questions
Helped
60071
Points
304
Start by cleaning the air filter, blow it out realy good, alot of times the carb gets dirty spray some carb cleaner in it just a little at a time, if you haven't changed the plug i would do that too.
1helpful
Carb ajustment
Only Info I see is "Homelite Chain Saws" - not much to go on.
Most saws have two carb adjustment screws, Hi, and Lo.
Assuming the saw will start and run enough to warm up, then
adjust the Lo screw in, clockwise, until the motor starts to slow down,
turn only about 1/8 turn at a time. From the point where it starts to slow down, turn it out about 1/4 turn. This should give you a decent idle. Now pull the throttle, and see what happens.
A - Saw runs up to speed, but dies off, or starts to slow on it's own.
turn Hi idle screw out about 1/4 turn.
B - Saw speeds up, but runs sluggish, fat - not real hi end.
Turn Hi screw IN, about 1/8 or so, and try again, or adjust
while running at full throttle. (best way)
IF it won't run well, try turning both screws all the way in to seat them, then come back out about 1-1/2 to 2 turns. this should get you in the ballpark to set things up as above.
Once the saw is running well, adjust the idle screw to a smooth idle but slow enough that the chain stops moving.
Stay safe
2helpful
Hi, on a poulan Titanium chain saw, what is the carb ajustment? Thanks Douglas Neil
Turn both jet screws CW to stops (lightly), then back both out 1-1/2 turns CCW each. This is a basic setting and the engine should start and run. Allow to warm up, then pull the throttle full on--the engine should 4-stroke. Adjust the H needle CW until the engine speeds up somewhat, but continues to 4-stroke. Correct adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. Release the throttle and adjust L CW until the engine runs fairly well, but still allows the engine to 'follow-the-throttle'. Adjust idle speed so that the chain stops turning, but the engine continues to run. Hope this helps!
3helpful
Poulan chain saw will not stay running after i start it. What are the carb settings ?
a good starting point is the low speed screw at 1 3/4 turns and the high side at 1 1/2 turns. Hope it helps
Have a poulan chainsaw that won't idle/stay running and bogs down when you press the trigger control. Do you need a certain wrench to adjust carb??
no carb ajustment is done with a flat head screwdriver, first i would remove the card, disassemble it and blast it with compressed air because its probably just clogged up with varnish. to ajust the high low and idle screws bottom both out ( turn in all the way) then unscrew each one turn. from there start the saw and loosen in 1/4 turn at a time until it runs well
2helpful
Need carb h/l ajustemts and idle controle ajustment
This does take a little time to get it just right. Start at one full turn for the h and l. Work on the high first and after you get the H running work on the Low. They have to work together. So if you get it to idle and run at full throttle but it hesitates when you pull the trigger just adjust the low a little higher.
1helpful
My eager ****** chain saw will not stay running ?
The 3 adjustment screws are Idle, high and low.
First figure out which screws are which adjustment. Tighten the screws then turn them 1 full turn.
Then start the saw and get it warmed up. Work on the high adjustment. This does take a little while. after you get the saw running at high speed work on the low speed.
1helpful
Need chain saw fix
I would try Poulanpro.com and look at their user manuals for the adjustment. They are different on most saws. Hope this helps
Top Oregon Scientific Measuring Tools & Sensors Experts
Dave Parker
Dave Parker
Level 1 Expert
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
