Do not try cleaning it with a cotton swob or enter a cheat code at the main screen because that didn't work for me but my DSlite is reading my Game Boy Advance games just fine but whatever DS game that I try it will not read it!!!!!!!!!!!
HELP ME NINTENDOOOOOO!!!! !!!!PLEEAASSEE!!!!!!!!!
Love,
C41tl3n
P.S. This is a question and what I tried to do. Not the soulution but if I figure out the answer I will let you know
Try a cleaning kit and clean the game slot contacts and game cartridge.
SOURCE: Some nintendo dsi games work, some don't.
More than likely it's because the contacts are not conducting correctly; this is probably because they're dirty... try to clean them with some rubbing alcohol...
WARNING: if done wrong, this can damage things... so you might want to try looking up something on youtube witth video instructions...
The blowing idea isn't bad either (if the block is simple) and, hey, it worked on NES.... ;)
SOURCE: When i insert a game
Use a small torch and look inside the game slot. It is most likely that one of the contact pins has been bent and is not macking contact. If any pins look mor bent than the others you may be able to bend it back into place. Remove the battery before you try any repairs (the battery is under the battery cover on the bottom of the DSi). After removing the battery, use a suitable tool such as a small screwdriver or an unbent paperclip to gently bend the pin back to the same position as the other pins. If the pin is too far bent to be repaired, then the game slot can be replaced but this requires desoldering of the game slot and this is not a task for a novice.
