Can**nt use the navigation system on the gps it says fatal error: initiation error. ** LANGUAGE FILES FOUND.
Error 1706: ** valid source could be found for product ASUS R300 GPS CATCHER WINDOWS INSTALLER CAN**T CONTINUE
Also says error 1603- fatal error during installation
Yes..I saw that..need teh model number of the actual gps you are using, please..
well, that's your call. but without the model number, we're flying blind over here.
well...for the future on this sort of issue, you can only expect someone to work from the available information. There is an answer to this, and if you wish, I will proceed. It's your call..frustration is apparent and undertstandable.
so, this is from Polaroid, then..
thanks..I'll see what I can find...ASUS is a general manufacturer in Asia, that makes tons of electronics
ok..so you're installing this from your computer? what o/s you using?
i can arrange a tech support call in about an hour, after I have b'fast here on HI..if you're open to that, see this link for how to make that call
Model # is E3403. Any I have not found a solution to this problem! I really was not instructed as to how to do whatever it is i have to do to fix this problem. So navigation system does not work!!! This is for the R30 portable gps
I am unable to contact the manufacturer today and paid for the premium assistance. Hoping to receive a solution or step by step instruction as to how to repair this navigation system.
Thank you! Hope to hear from someone soon re R300 portable gps
Not frusted with tech support for this R300 portable gps w/auto light sensor and bluetooh Mfg. part 90WG-S0430000 Not sure what other info i could give you to help you with solving the problem.
This was made by ASUS
