Do you find that the boiler water pressure drops over time?
Then replace the pressure relief valve. You'll find it in the lower part of the boiler connected to that external pipe.
Close off the water pipes to & from the boiler and then replace
On some you can dismantle the valve and clean the scale from the inside and it works again - but not always 100%
It's either this or the fill tap/valve is not turned off fully
