Life Fitness 9500HR Next Generation Remanufactured Treadmill Logo
Posted on Mar 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Communication timeout message on a display - Life Fitness 9500HR Next Generation Remanufactured Treadmill
John Mazmanian
Level 3:
President:
  • Life Fitness Master 832 Answers
  • Posted on Mar 15, 2010
John Mazmanian
Life Fitness Master
Level 3:
President:
Answers
832
Questions
0
Helped
628337
Points
2056
You need to press and hold Pause,press clear twice. Continue to hold pause until the display reads SERVICE MENU. Press any up arrow and select SYSTEM TEST. then press enter in the desired mode,then the display will scroll automatically though available options. You want the first option which is SYSTEM COMM TEST hit enter upon do so it will perform test to communicate with all module within the treadmill. If a module does not respond to the upper console the a error message will display.
1helpful
2answers
Hp lj 2300 55.40 error shown on display
55.4 is Communication timeout. It is about communication between electronic components inside and indicates bad or broken connection. Are you sure there is zero after the 4?
Bosch shx36l05uc/21: After running diagnostics the 'wash' button keeps flashing, can someone tell me what the problem is?
Hi Jeff, As you can see there's 3 different Bosh washing machine models, Hope you can find your error code.... CHEERS..
Bosch Washing Machine Fault Codes
F16 - Door lock error
F17 - Inlet valve error detected
F18 - Drain error detected
F23 - Anti flood device has been activated
F34 - Door lock error
F42 - Motor fault
F43 - Motor fault
F44 - Motor fault
Bosch WAE Range Washing Machine Fault Codes
F16 - Door lock problem
F17 - Inlet valve
F18 - Drain pump
F21 - Motor
F23 - Anti flood system activated
Bosch WFP Range Washing Machine Fault Codes
F01 - Water intake timeout
F02 - Heating timeout
F03 - Draining timeout
F04 - Motor fault
F05 - Uncontrolled motor startup
F06 - Short on NTC Detected on hot water intake
F07 - Open circuit NTC Open circuit wiring
F08 - Door open when program started
F09 - Unexpected heating
F10 - Communication error
F11 - Overheating
F12 - Short circuit
F13 - Mains voltage too high
F14 - Mains voltage too low
F15 - Faulty temperature sensor on motor PCB
F16 - Faulty rinse sensor Displayed only in test
Nikon l23 coolpix displays watchdog timeout on powering up? Or when turned on?
I can't find any timeout error. Perhaps you look in the manual from page 119, where all error messages are, to see what the camera tries to tell you. there are a lot of warnings and errors with a little clock symbol.
May 30, 2014 • Cameras
F9-88 code on arm317
F9-88 = Print PCB to Main MFP Board Comm Timeout
You can clear this by turning your copier off and then on. Try turning it back on with the network cable unplugged, run your machine, then plug the network cable back in. If the error code comes back, its: 1) bad network cable 2) ungrounded electrical plug for copier or router 3) noise on network line 4) copier needs firmware update 5) replace the print board
Gateway timeout error 504
If your router is spitting out a 504 error, that usually means the site its trying to communicate with is down. More specifically, the server is not responding to the data packets being sent out, as such your router displays a 504 timeout error.
If your trying to access a certain web page or site, then its probably that groups servers or networking equipment having problems, and their is nothing you can do about it. However, if your trying to get to www.google.com and you get the same error, then you have a problem. If that is the case, you will need to troubleshoot your computer/equipment.
Why cant i watch anything on youtube. it will not work at all.....it says time out.
Webpages timeout with an extensive display of resources. First, the factors that predict website network displays are structures that computers are built. For example, dial up telephone line internet structures are least multimedia compartible. Once requested media that least displays initiatially timesout as notification of incapability. Second, the timeout conditons occurs with requesting resources from another device that least has the capacity to produce. A computer network provides notification as timeout saving integrity of surfer. Third, timeout is encouted in conditons that network malfunctions were experienced. In such a situation either as the device structures have least compartible conditions or another devices is encountering situations least producing results. Solving website timeout conditions. First, restablish the network also called refreshing either connection or websites or pages. Second, in a situation that an observable malfunction were encounted requires repairs to take effect.
Describe your AT&T BlackBerry Curve
BlackBerry smartphones support individual security passwords between four and 14 characters in length. The use of the password is designed to make sure that only the BlackBerry smartphone user can access the information stored on the BlackBerry smartphone.
The BlackBerry smartphone rejects less secure passwords, such as those composed of identical characters or those that consist of natural sequences (for example, 1234). In instances such as these, the BlackBerry smartphone will display the message The password cannot be a sequence.
Set a BlackBerry smartphone password
  1. From the Home screen of the BlackBerry smartphone, click Options.
  2. Click Security Options.
  3. Click General Settings. Note: If you are running BlackBerry® Device Software 4.0.2 or earlier, click Options, and then Security.
  4. Change the Password field to Enabled.
  5. Display the menu and click Save.
  6. Type your new password and click Enter.
  7. Verify your new password by typing it again and click Enter.
Change the BlackBerry smartphone password
  3. Click General Settings. Note: If you are running BlackBerry Device Software 4.0.2 or earlier, click Options, and then Security.
  4. Display the menu and click Change Password.
  5. Type your existing password and click Enter.
Turn on password protection using the Security Timeout feature Security Timeout is a feature that, after a predetermined amount of inactivity, will lock the BlackBerry smartphone automatically.
To turn on Security Timeout, complete the following steps:
  4. Set the Security Timeout field to the amount of inactive time the BlackBerry smartphone is permitted before it is locked automatically.
Note: Clicking Lock on the Home screen instantly locks the BlackBerry smartphone.
Unlock the BlackBerry smartphone
  1. Press any key on the BlackBerry smartphone to display the Enter Password screen.
  2. Type your BlackBerry smartphone password. Press Enter.
Important: If a password in incorrectly typed ten consecutive times, all of the information on the BlackBerry smartphone is automatically deleted. This is a security feature.
Additional Information When the Security Timeout feature is set for a longer duration than the Backlight Timeout feature, the BlackBerry smartphone will lock automatically when the combined duration of the features has elapsed. For example, if the Backlight Timeout feature is set to dim after two minutes and the Security Timeout feature is set for 20 minutes, the BlackBerry smartphone will not automatically lock until 22 minutes has elapsed.
Message ID . . . . . . : CPA403D Severity . . . . . . . : 99 Message type . . . . . : Inquiry Date sent . . . . . . : 12/11/08 Time sent . . . . . . : 15:13:47 Message . . . . : Operator action required on...
This is a JetDirect error and can be cured by adjusting the IO and Idle timeout values. Set the IO Timeout (or Job Timeout) to 300 seconds ( 5 minutes) and set the Idle Timeout to somewhere between 900 seconds (15 minutes) and 3600 seconds (1 hour). Setting the IO Timeout (or Job Timeout) and Idle Timeout to 0 does not disable them. It causes the printer and/or print server to timeout immediately. The IO Timeout can typically be set through the control panel on the printer, or it can be set using the HP JetAdmin Utility. The Idle Timeout can be set by TELNETing to the TCP/IP address for the printer, or it can be set using the HP JetAdmin Utility. The HP JetAdmin Utility can be downloaded from HP's Web site, www.hp.com.
The print job is defaulting to tray 1 so you will need to change this at the application and printer driver admin and not at the printer itself.
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
