I can not get my Maytag Neptune TL into service mode.
Enter / Exit Service Mode
To enter Service Mode press the Enviro Plus and Spin
Only keys for three seconds or until the control beeps.
Membrane Pad Test
While in Service Mode, pressing the Presoak key will
start a membrane switch check that verifies switch
operation. All the LEDs (except Presoak ) can be toggled
or slewed by pressing the key associated with the LED or
set of LEDs. Each time either set delay arrow is pressed
the digits toggle between a blank and 8. All keys
(including the OFF button) must be pressed within 5
minutes for this test to pass. “PA” will be displayed for
five (5) seconds once all keys have been pressed and the
test is completed. Following 10 seconds of inactivity at
any point, this test will exit without any display.
if still the same problem.then its the fault in the timer or the main control board.
it has to be checked.
if not familiar with doing this then you can get it checked by local appliance repair technician familiar with this brand and model.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Spin Only keys for three seconds or until
the control beeps.
Do the above procedure to exit the service mode and then turn off and unplug the machine..
Press Keys Special Test/ Function
wrinkle
release Diagnostic Codes
dryer
temp(^ )
Sequences up the
help/diagnostic code list
dryer temp(v) Sequences down the
time (-) Displays Software Revision
Number
very dry(< ) View current cycle
temperature (Co)
start/pause
Start or pause cycle running
but remain in Diagnostic
mode
After the machine is in the diagnostic mode,
a ‘d’ will display and let the technician know
they are in the diagnostic mode. Pressing the
wrinkle release key will access the diagnostic
codes.The diagnostic codes can be viewed by
using the temperature (^) & (v) keys.
The down arrow key will sequence down the
list one each time it is pushed with no wrap.
The first time the down arrow key is pushed
the display will sequence to the next code
logged. The last code being displayed being
the oldest code. The up arrow will sequence
up the list one code each time it is pushed
until it reaches the top code. If there are no
diagnostic codes available, ‘00‘ will be
displayed for the diagnostic code.
There will be no multiple occurrences of
either a diagnostic code or help code generated
in the same cycle reported on the list.
But if the same code occurs in repeated
cycles, it will be registered.
To clear the diagnostic code list press
wrinkle prevent and very dry (>) for 5
seconds while viewing the list.
System Check Mode
While in diagnostic mode, pressing the damp
dry and signal (+) keys for 2 seconds, will
put the dryer into the system check mode.
"SC" will display.
This mode will allow the various inputs and
outputs to be controlled and viewed by the
technician by pressing individual keys. If no
activity is seen for 5 minutes after a key is
depressed, the control will reset back to the
normal mode. If no further activity is seen
after an additional 5 minutes the washer will
turn off. The following table lists the various
functions based upon on keys being depressed.
Membrane
There is a PDF document here that shows hoe to access service mode, section 9-7.
http://www.servicematters.com/maytag_library/docs/16023110.pdf
There is not a "diagnostic mode" for the neptune washer.
All tests and functionality are done at each setting using the timer (except the tach circuit)
What is the problem you are looking to diagnose??
Thanks!
Usually, the timer is replaced for this failure - however, yours is integrated on the main circuit board. and not seperately serviceable.
The Controller board must be replaced.
SEE A REPLACEMENT HERE
Thanks!
SOURCE: Maytag Neptune TL
Lr stands for motor not running properly. Solution says to call for service.
SOURCE: maytag neptune tl
Code OP means lid is open. If it really isn't, then the problem is with the switch that sense whether the lid is shut or not. Could be bad switch or bad connection.
SOURCE: Maytag Neptune Tl FAV6800A stuck in wash cycle
Hello rockhead255 ,
I'm an owner like you and will try to help.
Error code 10 states Unbalance or cabinet hit detected during final spin, which prevented the spinner from exceeding 500 rpm
Did you notice if you took some large tub swings as the washer tried to spin up?
I suspect a Clutch malfunction. Pump the water out of the tub with the Board Output Test with the drain pump in service mode. With the wash tub empty open the lid and see if you can rotate the wash basket CCW with one finger. You mentioned “”Tub does not turn by hand””. Is that in the CCW direction?
You should be able to rotate the wash basket with your pinky finger with very little force. The wash basket will not rotate CW. What amount of rotational resistance do you detect in the CCW direction? With the error 10 reported I would drop the clutch out of the machine per my step by step procedure at this post. Try the One-Way roller clutch bearing clean up and re-lube as I discuss in that post and see if you can restore the machine to normal Spin operation. Once you drop the clutch out of the machine we will have a better feel for the issue.
You can try the TDS check in the SM but I feel it is a Clutch issue at this point of troubleshooting. Good troubleshooting using the machines diag code listing.
Post back if you havd need additional questions or help.
Rich
Testimonial: "Thanks for the answer, I will try these when I get home this afternoon."
Neptune TL Washer FAV6800AWW
Go to the 5th post down there is a link to the Service Manual. The Service Manual will show you how to get into Service Manual and unlock the lid Locks. If you can't unlock in Service Mode the Service Manual will show you how to release the washer top from thew base to remove your clothes.
If you need additional help post in that forum for help ; Maytag/Magic Chef/Admiral/Jenn-Air
In the Sticky: Neptune TL Washer FAV6800AWW 5 post down you will find a link to the Service Manual. You absolutely need the Service Manual to DIY issues with the machine. It's not the best SM but will get you started. I also have repair post in that sticky to help with the most common issues that I have helped owners with. I'm an owner of a FAV6800AWW top load machine.
If you want help post your issue in that Maytag DIY froum and I will help you......or stay here and see how it's goes.
Why does the service manual say there is?
the washer will start to wash then get hung up. It will continue to try and wash over and over the timer never goes down during this time.
I have a Neptune Maytag TL. When I start a wash the machine wants to hang up on the wash cycle. The timer will stop advancing and there is a 2 or 3 second tumble then it will stop. A minute later it will tumble of 2-3 seconds then stop.
Is the ccu board the same as the control board?
I have a Maytag Neptune TL FAV6800AWW: The washer will load up with water, start to tumble then gets hung up tumbling for a few seconds then gets hung up on this process. It will tumble, then stop for 30 seconds then tumble for a few seconds then stop for 30, on and on. During this the timer never advances. I tried to put it in service mode it will not go into service mode. I was told earlier "I need to memory for the computer has corrupted itself and will need to be replaced the CCU board of the machine needs replacement." Is trhis the same as the control board?
