It could be how you have it wired. 2 way switches can be tricky. One of switches will have a wire run to the chandelier and this is where your dimmer should go. Here's a link to a explanation of 2 way wiring. Hopefully this will help. If you want to check to see if it is the bulbs, you could put in non energy efficient bulbs although I think it's another problem. If it was the bulbs, the dimmer would at least turn on the energy efficient bulbs in the low position. Good luck!
Link to 2 way switch diagram
http://2wayswitch.com/2-way-switch-wiring-diagram/
Oops. Meant to say dimmer would turn OFF the lights in the low position.
Just curious what happened with your project as you dropped your rating of this tip.
Here's a link to an explanation of dimmers and 2 (or 3) way switches. There are actually several ways to wire these depending on your goal. They can even be wired with a normal (non 3 way) dimmer.
http://www.ezdiyelectricity.com/?p=441
