My o2 goes to hard reset when press button to unlock
When i press button on the top (near memory slot) to unlock my o2.... its go to hard reset... why its happened
and also it reset button not funtion. nothing happen when i press it.
Chances are Hard resetting your phone, but take note that all data will be lost.
Here is the Procedure
1. Press and hold GPS/Messaging and the Internet Explorer button,and at the same time need a stylus to press the reset button at the bottom of your phone.
2. Released the reset button but continue the two keys, until you see a message on the screen that all of your data will be deleted.
3. released the two buttons and then press SEND button on your device to perform the hard reset or you may even cancel the reset by pressing a button.
For more illustration and clear visualization, you can view this link;
To perform a hard reset, use the stylus while pressing into the reset hole, press the power on/off button at the same time. Screen will prompt you to press the Green call and Red end call button together to confirm on hard resetting the device. *Note: Hard resetting the device will cause the device to be reset back to its original factory default settings and all data will be lost.
- Soft Reset: Power cycle your handset, no data is missing. - Hard Reset: Power cycle your handset and erase all data, rollback your device to default state (when you got it first time from the store/factory).
How To: - Soft Reset: Press the small Reset button on the up side of the handset, near the power button - Hard Reset: 1) Go to Start Menu >> Settings >> System >> Hard Reset >> Clear Memory >> and follow instruction. 2) or other way is: handset in power off state, push small Reset button near the power button while also pressing End & Call button simultaneously and then follow instruction appears on the screen.
I think you can only do a Hard Reset to your Omnia.
But keep in mind that by doing a Hard Reset, all your data and installed third party application will be erased.
store/factory).
How To: - Hard
The digitizer on top of the lcd display is most likely faulty, try a hard reset, if it doesn't solve the problem the digitizer would need to be replaced.
1. Press and hold the Comm Manager button and Voice Command
button on the device.
2. Keep the two buttons pressed, and at the same time, use the
stylus to lightly press and hold the RESET button.
To perform a full reset A full device reset clears memory, deletes all data, and restores the Pocket PC Phone to its default settings. Programs installed at the factory remain. All data that you have created and programs you have installed are erased.
Press and hold the Power button, and then use your stylus to press the “soft reset button” at the same time. Be sure you have backed up all your data on an SD card or on a desktop PC before performing a full reset. Hope this helps.
Couple of things you can try to fix the issue, firstly try a hard reset
Try that and if it doesnt resolve the issue then we can try another solution
