I HAVE THE EXACT SAME PROBLEM AND THEY WANT $120 FOR ANOTHER CONVERTER BOX FROM CALIFORNIA....THEY NEED TO GIVE ONE FOR FREE !I HAVE THE EXACT SAME PROBLEM AND THEY WANT $120 FOR ANOTHER CONVERTER BOX FROM CALIFORNIA....THEY NEED TO GIVE ONE FOR FREE !
You can't post conmments that contain an email address.
every since television went digital, rabbit ears are hard to get to work. you will probablty have to get a digital converter box for it first, attach rabbit ears to converter box and box to television the same way you would attach cable
Your tv is a digital tv, so you do NOT need a converter box. The tv has a built in digital tuner. But if you have any other older tv's then what you need is a converter box to convert analog signals to digital. I know there is one in Best Buy (not sure if there is one in your location) but they have one called access digital tv converter. They are about $50 (CAN). You would still need your antenna or however you get your analog signals. The antenna needs to be plugged into your converter box and then the box would need to be connected to your tv.
one try is to unplug the tv and then hold the power button in for 20 seconds then plug the tv in an see if this works. I had a 32 in rca tube an this worked for me
The Sony KV-32S120 has an analog tuner. If you use it with an antenna, you'll need a digital converter box. If you're a cable tv subscriber, the cable company will do the conversion and you won't need anything. Here's what Sony says about it...
If there is no digital tuner built into the tv or unless you subscribe to Cable TV or Satellite service you will still need a converter to view tv with rabbit ears (air broadcast).
AC Adapter not working
i do have the same problem
