If Win7-64 is installing this hub as a "Broadcom Bluetooth Device" or some such nonsense, heres a fix that has FINALLY worked for me...
START > CONTROL PANEL > HARDWARE AND SOUND > Device Manager.
Plug in your hub, and when it pops up under bluetooth radios with an error, right click, then select properties.
Under properties, select the DRIVER tab, then select UPDATE DRIVER.
It should prompt you to choose between "Search Automatically..." or "Browse my computer..."
Choose "Browse my computer for driver software."
It should bring up a location box to search, but there should be an option below the box that says "Let me pick from a list of device drivers on my computer."
Select this option.
This will bring up a list of drivers available.
UNCHECK the "Show compatible hardware" box!!!!!!!
Then browse until you see (Generic USB Hub). Select the first driver on this list and it will work.
The windows generic driver file that works with my hub is in:
C:\Windows\system32\drivers\usbhub.sys
If the above solution doesn't work, you can try to navigate to this specific driver file during a manual installation. Good luck.
USB hubs are compatible with all the operating systems...check for the USB drivers in your computer....
SOURCE: not sure
Every plug and play devices are compatible with Vista.Vista have a huge range of drivers under its hood.So there is no doubt on that belkin usb 2.0 lighted travel hub is compatable with windows vista
SOURCE: Belkin F4U017 7 port USB
I just had the same problem and was able to figure our a permanent fix.Judging by the date of you post, I'm guessing you've already remedied this problem one way or another. But just in case you haven't or someone else is having the same problem, I'll go ahead and post what to do. First, make sure you leave the USB hub plugged in right now so that Device Manager lists what it thinks is the Bluetooth device. Go into Control Manager > Hardware & Sound > Device Manager. Right click on Bluetooth device that is showing up in error. From the dropdown box, select Properties. Click the Driver Tab. Click Uninstall. Check "Delete the driver software for this device." Click OK. Unplug your USB hub for a few seconds, then plug it back in. Windows should now recognize it as a "Generic USB hub." You should be good to go. Just remember not to install that update again or try to update the driver for the Generic USB hub. If you do, you'll end up with the same problem. I hope this helps someone out there.
