Shoprider Sunrunner 4 - 4 Wheel Scooter Logo
Anonymous Posted on Mar 15, 2010
Trip breaker,reset it but no power to anything. what is problem?
Anonymous
Level 2:
Scholar:
  • Expert 61 Answers
  • Posted on Mar 18, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
61
Questions
0
Helped
47622
Points
105
Probably just a fuse somewhere. Does your battery meter work? If not, there may be a fuse on the battery harness thats blown. Failing that, depending on what make of control box is fitted to your scooter, it could be a fuse within this that has blown.
Testimonial: "thanks a bunch"
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 18, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
616
Points
With my Victory (Pride) there was a blown fuse in the steering column (you need to remove 5 screws on the plastic panel (side closest to the seat) and one more just behind the basket.
My Kenmore Elite Upright Vacuum stopped working.
It might sound very easy , but lack of power is usually the cause of a vacuum cleaner that is not working . Check that the vacuum cleaner is plugged into a working power outlet and that fuses and breakers don't need resetting. An activated thermal cut-out due to a blockage is the next most likely cause of the problem.
Tripped Circuit Breaker/ Blown Fuse
Check service panel for tripped breakers/blown fuses. If breaker is tripped, reset it. If fuse is blown, replace it. If vacuum cleaner is plugged in, make sure that the power button is in the off position before having to reset the breaker/changing fuse.
Briggs and Strattion portable generator model 030324-0, 5550 watts. Has 220 but no 110 power.
There are reset breakers on the control panel. If the 110 outlets are GFI protected then the issue could be your cord or appliance. Please try some other type of item (Tool or lamp). If the breaker was over whelmed and tripped the breaker. The breaker is labeled and mounted on the control panel as well. Please write back if there is anything else.
2answers
Blowing15ampbreaker
Do you mean tripping a 15 amp breaker?
Unlikely a breaker will blow.
If the breaker trips as soon as it is reset without any appliance being connected to that circuit there is a fault with the circuit. Damp or water ingress is common as is an attack by rodents, mice will be able to access cables easily and will attempt to make a meal out of anything.
If a breaker trips when an appliance is connected or switched on the fault is clearly in the appliance or possibly in the power cord.
1helpful
2answers
Home electrical
Hi Sammy,
It sounds like there is a direct short on the circuit. Before going any further, check other outlets on this circuit and make sure they do not have anything plugged in that is not expected and does not work. Check OUTSIDE your home, basement, garage, etc. as these locations require GFI protection - and may be fed from the bathroom outlet. After removing devices that are plugged into the circuit, attempt a reset of the breaker once more.
It is not likely that the circuit breaker has failed (but is a possibility). The outlet in the bathroom is probably a GFI type. You can determine this if it has "Test" and "Reset" buttons on it. You should be able to press the Reset button in fully even with power off. After resetting, you can attempt the resetting the circuit breaker as you have described above. If it stays on, try pressing the "Test" button on the outlet. Doing so should trip power to the outlet (and causing the "Reset" button to pop out) but leave the circuit breaker "On". If the breaker also trips, the GFI outlet is suspect and might need to be replaced.
At this point, a qualified electrician should be consulted to locate and clear the wiring fault.
Apr 24, 2013 • Hammering
What's youI just wired in my J-300 Jacuzzi hot tub. The GFI trips every time I reset it. I took the GFI out of the equation and the tub runs fine, does not trip the breaker at the main breaker box
#1. DO NOT GET INTO TUB FULL OF WATER WITH A GROUND FAULT.
2. There is a short. You need to get multimeter and start checking each part for current running to ground wire.
3) Power is ON. Connect power without GFCI.
4) Tape tester leads to wood sticks to keep hands away from power.
5) Do not touch anything directly or you will become the ground rod.
6) Ground wire must be present, and bonded back to main panel box.
7) Do not sit or touch directly on cement or bare ground. Do not touch or lean into anything made of metal.
8) Body and parts must be on sheet of plywood, or similar non-conductive dry surface.
9) Test each part with spa, but also test electric line coming from main box.
10) GFCI will also trip with any fault detected on line. So the wire coming to spa may have the fault.
11) Add a new dedicated line from main box to spa.
http://waterheatertimer.org/How-to-wire-GFCI.html
http://waterheatertimer.org/See-inside-main-breaker-box.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
E442 Fridge Was noisy, now trips mains power :(
Sounds like the compressor is grounded out causing the breaker to trip, but it could also be wiring, but if I recall most things in those type of machines reduce down to 12vdc and that wouldn't blow the breaker.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
I have had my whirlpool dryer about 4yrs + (geq9800pw2) has always worked fine. Last week it started tripping ckt breaker toward the end of drying cycle. As of this morning, it blows ckt breaker...
leave off the oven and a/c breakers and plug dryer and reset the breaker. if not tripping occurs then one at a time trip back the oven first. if no trip then trip off again and trip the a/c. if no trip then trip the oven back. if trip you may have a wire problem. if dryer trip any way then possibly you have a short in dryer. check the heating element wires,power cord at the dryer side(terminal block).
Feb 14, 2011 • Dryers
Doesn't appear that the washer is running through its cycle. The soap packet isn't desolving and no water is on the plates. There was an incident when the washer tripped the circuit breaker, reset breaker...
I think something went wrong with your motor or the inlet Solenoid valve. That was the reason for the trip.
Take service center help!
Hope you are getting power after resetting the trip.
20amp breaker tripped unexpectly tonight. tried resetting at panel but won't click all the way over and little red indicator also on the breaker
Hello, In order to reset circuit breakers that have tripped under load, you must first flip the breaker all the way OFF, before you can then turn the breaker back ON. This should reset the breaker to turn the power back on to the circuit supplied by this breaker.
The red indicator is just there to make it easier to find the tripped breaker. Typically, the red indicator flag is a special feature of Square D QD breakers and panels.
If the breaker immediately trips again and doesn't stay on, then the device it is providing power to, still has a fault and it needs to be looked at to determine what is causing the fault and the tripping of the breaker.
Be sure to turn the breaker OFF if you are going to check the device for potential problems.
I hope you find this Very Helpful and best regards!
2answers
3-pole 60 Amp Circuit Breaker is tripped and won't reset.
When this breaker tripped, it did not go fully to off. Push the breaker all the way off and then all the way to on. It should be fine. If not manually push it to full off once again and then back on. If both attempts fail the breaker will have to be replaced. good luck.
Top Shoprider Health & Beauty Experts
Rob Hill
Rob Hill
NOEL
NOEL
jws1013
Are you a Shoprider Health and Beauty Expert? Answer questions, earn points and help others
