Probably but you have to be careful that the weight of the oil is appropriate - hopefully it says what weight oil to add. Adding oil that is too thin may cause leakage/dripping onto your projects. Adding oil that it too thick may cause the unit to run loudly and not get proper lube.
Also, some synthetic oils do not blend well with common oils and may form an emulsion (like mayo). If it is very old, using cheaper common oil won't hurt it. I would stick with the common oil unless you clean out the old oil from the tank.
Good luck and please rate me.
